Car Stalled And Won't Start, Turns Over, Has Spark And Fuel, Ideas?
I have experienced your exact symptoms on 3 events. 2 of them were the head gasket, and the third was a snapped exhaust cam.
I highly recommend doing a comp test first, as if a cam snapped you will get a bung reading too and then take off the rocker covers.
Hope it works out OK. If your in Sydney/Bankstown local I can lend you a comp gauge if you need be.
I am having the same problems at the moment mine made a small backfire and then started dieing but I was driving on the highway not even Gettin under boost got a second hand cas and still the same. the exhaust temp light came on after it stalled out aswell
Chances of consult cable working is minimal... Unless your CAS is working but way off you wont get any reading from the consult. The fact you have spare and fuel verifies this.
Do the checks I mentioned. Checking coolant and oil for contamination only works SOME of the time when checking for a HG. You must comp test.
And yes, snapped cam = valve meets piston officially after years of anticipation and sexual frustration.
Wouldnt piston and valve love make a horrible crunching sound and eventually seize? eg something I couldn't miss trying to turn it over 100x?
First thing I will do when I get back is check coolant and oil for signs of headgasket, then try new cas, if no go I will arrange to get a compression tester off a mate, thanks for the offer but I'm over in SA.
Appreciate all the suggestions everyone.
sounds to me very much like a timing related problem. usually when your timing is out it will backfire thro the intake. I would be pulling the cam gear cover off and putting the motor at TDC and checking the timing marks are all lined up.
failing that... your fuel pump could be f**ked.. might have enough pressure to prime but then dies off leaving you with bugger all rail pressure.
I am actually thinking fuel reg, it makes weird noises when priming cold however we checked AFRs on 18psi for a long time on the dyno and they never once showed any signs of leaning, however is is possible that it went from fine to the diaphragm dying and having f**k all pressure. The weird backfires are making me think it is timing though.
So order Im going to do things:
Check for signs of head gasket
Try new cas
pull plugs and see if it spins really fast / compression test
replace fuel reg
somewhere in there I am going to get the consult on there, waiting for my mate to get back from interstate.
bunno32gtr a consult cable lets you talk to the ECU via a laptop and you can pull error codes and check the values of basically all sensors.
edit: really hope the battery still has some juice to turn over, cbf getting there and having to hail a random to come jump it.
Edited by Rolls
You have had something go pop and then the motor suddenly stopped. Even if it didnt go pop a sudden stop does not indicate something that would gradually die, IE fuel pump or reg.
Fact is you still have fuel and spark, start thinking more mechanical based.
And no piston and valve contact via a snapped cam would not result in crunch sounds. The cam may have snapped at a point it did not make contact OR it could have snapped and the 1 x piston to valve contact moment would have spun the cam back to a closed position like it did when it happened to me.
Experience at work ^
Ok thanks for that, compression test will certainly show that up if it is what has happened, will try and organise to get one in the next day.
You need to make sure all the timing marks line up first. Stop cranking that engine over. If you have bent a valve, you risk snapping it, then the next rotation could drive the stem into the head. Backfires indicate a timing issue of some sort. As above, make sure those marks are aligned before proceeding......for the sake of knowing you aren't doing any further damage
bottom crank balancer mark needs to line up with the notch on the timing cover. this is TDC. pull number 1 spark plug out and use a blunt object down the bore on top of the piston to confirm this as you rotate the crank. the highest point is TDC.
then.. the two cam gears must line up with their corrosponding marks.. theres a dot on the cam and a line on the backing plate of the cover.
if they are out by even 1 tooth.. something is f**ked
The engine will still start if it's one tooth only. He would be looking for 2 or more teeth out so it should stand out pretty clear.
But yeah, even if it's moved one, something has gone wrong
I took a bit of a gamble and started it again with the new cas, no luck so shut it off. Won't attempt to turn it over until I've got the timing confirmed and done a compression test now.
Thanks for the advice simon and elite, can't be f**ked taking enough tools to take all the front shit off in my back pack so gonna tow it home and go from there.
Worst case and I have smashed everything inside, what's a bare 25 block and head worth these days ~$1k ?
How does it sound at the moment? Like when you crank it are you getting that up/down sound you get with decent compression?
I would have thought the comp would be in a pretty bad way not to atleast start and run rough, in which case the starting sound would be evidently different.
Fingers crossed the comp test comes up OK anyway.
Edited by James_03
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
