Hay Guys first day on here so hello as well lol, just bought myself a 1996 gtst series 2 totally factory bar a 3" straight through exhaust. I have a front mount for it just need fitting kit., what Mods can I do at a basic level without spending much cash at the mo to make it pretty quick.
Thank you and sorry if this is the 10000000000000000000000 time you have read this sort of question. lol
https://www.sau.com.au/forums/topic/354967-help-wanted/
Mate you'll always find the guys that call you a tosser for posting up questions like yours but some of us enjoy giving advice no matter how many times we've heard the question because its fun.
So your car...best bang for your buck mods are
Turbo back exhaust (if yours isn't)
FMIC (front mount intercooler) which you have - this is probably the most important upgrade you could do along with your exhaust if its not turbo back already.
CAI (cold air intake)
Stock R32 Wastegate Actuator (will get you up to 10psi, stock r33 actuator is limited to 7 or 8psi)
Boost Controller - if you want more boost (safely to about 14psi which is the limit of your stock turbo)
Power run and tune
This will give you approx 200-210rwkw and this is when you'll need the supporting mods for more power (injectors, fuel pump, z32 AFM, coil packs)
Jimmy
Edited by Plan-B
  • Like 1
  • Nope 1
https://www.sau.com.au/forums/topic/354967-help-wanted/#findComment-5684519
Many thanks Jimmy,
hay I dont mind people calling me a tosser for asking a question, everyone has to learn some were, I have raced bikes my hole life but now I only have part movement in my right arm i cannot race anymore. come over from the UK to live the good life so to speak. Thanks alot, is it easy to source these parts.
Karl
https://www.sau.com.au/forums/topic/354967-help-wanted/#findComment-5684666
Many thanks Jimmy,
Karl
Everything you need is on SAU Karl.
We have a Classified section where people can post up what they need/want to buy and also a trader section where businesses offering all the used/replacement/performance parts can be found.
Best way to do it is explore SAU and you will learn in leaps and bounds.
All the best brother.
  • Like 1
  • Nope 1
https://www.sau.com.au/forums/topic/354967-help-wanted/#findComment-5685972
wont make it fast, not needed
std snorkel will work and cost nothing, high flow filter maybe
bleed valve will work easier - turbosmart $40 and easier to install
dont need a boost controller if you have a bleed valve
Power run and tune
tune what exactly.... what make sure the timing is in... better off just buying some plugs and oil
I doubt it will give you 200rwkw
good one plan B, the original question was 'what Mods can I do at a basic level without spending much cash at the mo to make it pretty quick'
the best answer you could give would be 'not many, search be covered by more experienced people than me...'
https://www.sau.com.au/forums/topic/354967-help-wanted/#findComment-5686230
so you call "without spending much money" a $40 bleed valve and a high flow filter?
i think the guy has more to rub together than the peanuts you make from your decal business.
cop the sig, you fall into 2 categories there.
Edited by Plan-B
  • Like 1
  • Nope 1
https://www.sau.com.au/forums/topic/354967-help-wanted/#findComment-5686301
no I said a bleed valve and a high flow filter, said nothing about a pod... pods are gay, and I suppose you have one right???
You had the guy buying a whole heap of useless hardware and going for a power run and tune... thats really woeful & expensive advice that would do bugger all for him...
seriously stop giving bad advice and making crap posts...
and baggin me out for making some money on the side is really no way to go about proving yourself correct, lets just keep it on topic, you really dont know who you'll piss off on a forum.
https://www.sau.com.au/forums/topic/354967-help-wanted/#findComment-5686315
We'll let Fit n Fun decide what he wants. i think he will opt for a bit more than what you have suggested, personally.
  • Like 1
  • Nope 1
https://www.sau.com.au/forums/topic/354967-help-wanted/#findComment-5686359
32 wastegate actuator.... No
At 10psi the stock R33 ECU will throw it in to rich and retard and it will be either slow as F#@! or Jerk when it hits about 5000rpm.
your better off doing the high boost mod with the stock boost solenoid till you get an aftermarket ECU. The chances of getting up to 200rwkw with a stock ECU are slim
And I wouldnt put the turbo right on its borderline limit of 14psi
I ran 12psi safely for about a year and a half, turbo came off the car and still looked/felt fine
You own an R32 and you dont experience the same ECU safety measures as the R33's do, I've been there, trust me its alot better to just run the car at 7psi then wind it up further then that on factory ECU.
https://www.sau.com.au/forums/topic/354967-help-wanted/#findComment-5686466
spot on mate. 33gtst ecu will hit rich and retard at a boost seeting of 10 pound.
had to rectify the problem on 33 countless times.
im not sure why he would want to change the wastegate actuator. bad idea
coil packs in not a power related problem as a rule. more an age and heat thing. my 400kw 25/30 has a set of nissan coils on it.
https://www.sau.com.au/forums/topic/354967-help-wanted/#findComment-5686510
Hay guys all great info and will take it away with me Thank you, I have a FMIC now just need fitting kit, My exhaust is turbo back but still has cat in it.
So can someone just clear some thing up, its better to run 12psi NO MORE on stock turbo and change ECU is this correct. My car will be a daily driver so i still want it fast but not a rocket, i ride them pretty much every day.
Thank you all.
Karl
https://www.sau.com.au/forums/topic/354967-help-wanted/#findComment-5686665
If your worried run 11psi. You will need an aftermarket ecu for these boost levels to be worthwhile. Plenty of fun to be had at 7psi if you've only just got the car but. Look in the DIY section here for the constant 7psi boost mod. It's easy just a matter of cutting a wire and earthily it to the car basically. But look at the DIY for more info if you want to do this
https://www.sau.com.au/forums/topic/354967-help-wanted/#findComment-5688260
  • 1 month later...
thx guys, just a quick update, have got fmic fitted, pod, e-mange ultimate and boost controller, also hks bov, just need to through it all in and give it a tune up, i am in melbourne, any one specific i can go to who is good and not going to over tune it.
karl
https://www.sau.com.au/forums/topic/354967-help-wanted/#findComment-5746054
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
    • A 180SX has a much better look than a FD. The roofline is far superior being a fastback. It's popups look better. In a world where we all subconsciously add a little bit of low, and wheels of our preference, it's just more handsome than the FD is. The FD just looks 'bubbly' in comparison. It can come down to preference, sure. But "The FD is the BEST looking (on appearances alone) 90's JDM car without question?" Nah. Plenty of questions lol. I could think of 8 cars I think look fundamentally better, and probably a handful of ones that look about on par with a FD. (like say a SW20 MR2) I feel people like/overrate the FD because of it's mythicality/rarity, its rotary and it's unpredictable nature. It probably drives great, you can stuff a ton of tyre under there, has a unique sound, light as hell. I feel that people reading this thinking "YOU CANT RATE A 180 ABOVE A FD BECAUSE A 180 IS A CHEAP DRIFT BUCKET" prove the point about bias as to what the car represents, moreso than how it actually looks.. I feel the 80's boxy/squared off look is becoming better looking due to time, and 90's melted soap bar aesthetics have not aged well. (yet?) And this thread is purely about looks :p
    • A red or yellow S15 wins my vote, Ack that it just scraps in with the 90's cars theme, but they are great looking little sports car Next would be a A80 Supra (pre face lift), whilst the A80 has its own issues, I feel is the best looking larger GT car As for the FD, "I" feel that the reason it triggers me in a non-positve way when looking at one, is like looking at a high maintenance pretty girl who you know is mentally unstable and likely to explode for no apparent reason
    • Yes, it's because it has hips and bulges on the top/front surface, a tiny cockpit and roof, and the skin looks like it is stretched over muscle. The proportions are....perfect. Long nose, short rear, short roof. What's not to like? It continues the theme started with the S1, that peaked with the FC, being "looking like a front engined Porsche", while gaining a little more of the 60's Mustang coupe profile and stretching the skin more tightly over the understructure. The FD is definitely colour sensitive though. Like all Mazdas. There are plenty of details on it that changed over the years that were either better or worse, could have been done better the first time and/or never changed for the worse. But...the same can be said for the NSX. In fact, that's probably even more true for the NSX. I've also just worked out that part of the reason I don't like the rear of the NSX is that the integrated wing is too similar to that shitful R33 rear wing.
    • I wonder if people like the FD because it reminds them of old 60's roadsters and such. It just gives me such a 'roadster/soft cruising' vibe as opposed to anything more hard-edged and purposeful. That, mixed with 90's melted soap bar styling. It's hardly ugly, but it's kinda oddly proportioned to me, relative to about 10 other cars I had a think about based on this thread.
