[Sa ] 17X9 17X8 17 Inch Black 5 Spoke Rims, Avs / Advan Model 5, Perfect R32 Gtst Offset
Got a set of rims for sale, they are pretty standard 17x8 and 17x9 black 5 spoke rims, no gutter rash and in good condition. They need new tyres as the sidewall on the front right has a gash in it but holds air fine and the rear ones are fairly bald. They will drive you to the tyre shop but they certainly are not legal.
Here are some pictures. Not sure of the offset but they sit perfectly on an r32 gtst, sit about half a cm in the guards so they are legal and fill out the guards well, no scrubbing or anything like that.
Can possible organise cheap 2nd hand tyres if needed.
Can send interstate but will probably cost a bit.
Asking $450 ono
Can call on 0423 277 771 or PM on here.
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
