ok so i know the n1 blocks have a 24U number cast into the block, but is there any way to run the number through nissan to find out if it was just a bare block purchased or if it was a complete assembled n1 motor or taken out of a n1?
reason i ask is theres a car for sale with a supposedly n1 motor from a r33 in it, he didnt built it but the engine was like that from japan, so i just wanna know really if its just a n1 block with unknown internals or if its the real deal. but even if it is unknown internals surely it would be a well built motor? who would buy an n1 block to build a shit motor haha
discuss
https://www.sau.com.au/forums/topic/355019-n1-engine/
really no engine number cast into the block? if thats the case then this ones probably just been putchases bare and buit up as it has got a number.
i thought an engine number would be like a vin where u can run it through a system to see whats going on, hmm
https://www.sau.com.au/forums/topic/355019-n1-engine/#findComment-5686037
no there is no engine number check like the vin, I have tried too, mine has an engine number on it now also, because when the workshop that changed my engine over, took the broken one out, they stamped the same number on the new motor, which happened to the N1 engine, so now it just has a normal engine number, but the only checks you can do is of an entire car, so you need the correct VIN #, engine # and rego to find out info on that car, thats about the only check you have available. So if you have a car with a different motor in it you won't be able to find much!
thats been my experience anyway, just do the comp & leak down tests, along with all the usual things to look out for, wheather its an original N1 or built probably doesn't matter..
good luck
https://www.sau.com.au/forums/topic/355019-n1-engine/#findComment-5686478
N1 'crate' style motors still have ALL the inherrant issues that a normal RB26 bottom end has.
Oiling issues, block cracking/required strengthening etc etc.
So overall they are just overpriced stock motors as you need to strip them down and attend to all these issues. For the price of N1 bottom end you could build a BETTER bottom end without question using a normal 26 block and blow for blow - the motor you had build should be much stronger/resiliant.
Just because someone used a "N1 block" means very little about the internals or supposed "strength".
The only time N1 bottom ends have a use - is scrutenised types of class racing etc etc where it's a requirement.
https://www.sau.com.au/forums/topic/355019-n1-engine/#findComment-5686583
    • I went from stupid 600+HP setup, to an NA Barra in mine...
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
