Some news story about Nissan crashing into factory...
I've been looking for more info on this all day - to no avail...
On the radio news this morning there was a story of a 'young man' driving a 'Nissan sportscar' and crashing at high speed - through a factory - taking out lights and factory stuff and whatnot - landing on its wheels and the guy getting out with na'er a scratch. Was in Scoresby.
Police were amazed he was so unhurt and were 'discussing' it with the driver.
Anyone else heard it or got any more info?
James
Yeah - is weird. I would have thought it would at least be in the AAP news briefs... they said it at every news from 7.30am onwards.
Perhaps it was some strange dream...
Surely someone else here listens to the radio news in the morning? Was Nova100.
yeah i heard it as well, kinda strange i just dismissed it as bs as they said it was a nissan sportscar... i was thinking, well which one... if someone did a little research they could pretty easily identify it, if they actually saw it. They could well have been talking about a pulsar or a maxima as they are *sporty*
Sorry to brach off the subject but I notice a few of you guys have little links to you pics under you avatare. I put sum up today but no link. Did you have to do it or did it just apear? - Cheers (and sorry to whore)
i didn't do jack, so yeah just appeared.
maybe play with your profile/control panel, may update it or something
Yeah it was a " Young driver in a high powered Nissan twin turbo 300ZX sportscar"...
Apparently he was excessively speeding and lost it, hit the curb and flew into the air, crashing right through the second story of a factory. He walked away from it but unfortunately his car didn't......and we wonder why cops pick on import drivers, cause of IDIOTS like this!!!
In order for the pics to show as a link under your username, you need to make sure it's a 'personal gallery'
If you have any more q's, please do it via PM or start a new thread. :D
~K
yeah guys i was there....
went after mate who has a scanner rang me and told me where it was
basically a black 300zx TT was flying down the street at some ridiculous speed, crashed up the gutter, got massively airborne off a grassy hill in the factory's front garden, clipped the top of the office-level roof (a good 4m off the grass)
it then continued another 5 or 6m through the air and slammed through the corrugated sheetmetal wall of the wharehouse itself, continuing its flight path, hitting roof lighting, narrowly scraping massive steel pillars, and amazingly clearing all the heavy machinery on the floor that woulda made the landing nasty.
it eventually then fairly neatly crash landed in surprisingly good shape, the driver sustained just a few bruises really.....
the interesting thing is we heard from the 1st cop on the scene that there seems to have been a passenger in the car who fled the scene, as police dogs tracked a scent through the factory that led to a broken open side door....
freaky stuff !!!
crazy, i always thought 300zx's would fly pretty well.
I heard on the news he was going at least 200km/h and after he crashed he "allegedly" fled the scene of the accident.
Maybe he was hoping that no one would notice and he could come back later and pick his car up?
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
