Hey guys.
I'm currently contemplating buying a .63 rear housing (internally gated and v-band dump) for my 35/40 off Hypergear. Just wondering if anyone has used them in the past and where they happy with what they got.
Is it brand new gear that you get off them or just reconditioned parts and housings? I will probably end up going with them as it seems to be my best option at the moment.
https://www.sau.com.au/forums/topic/355061-hypergear/
Get a smaller turbo then.
Putting a .63 on a GT35 will cause undue restriction, and it won't improve things "much" better.
Yeah was thinking of buying a smaller turbo, but dont really have the funds at the moment to do so. I thought i may as well do with what i got at the moment.
Why would Garrett sell a GT35 turbo with a .63 rear housing option if it is not a real good option??
https://www.sau.com.au/forums/topic/355061-hypergear/#findComment-5685909
Because they already have the housing.
Offering an option is merely adding to product coverage.
The .63 has its place. But not on a RB25 with a 700hp turbo mate.
By the sound of it you'd be better off with a GT3071 which even in a .82 - would come on sooner than a GT35 with a .63 and be MUCH more linear and progressive (read: less epic wheel spin as boost hits)
https://www.sau.com.au/forums/topic/355061-hypergear/#findComment-5686433
Hypergear can provide you with what you want, from what i've seen all the housings etc he has are brand new, not reconditioned
but Ash is spot on the money, the turbo you have is better matched to a 3 - 4 Litre engine, not a 2.5L
and i understand you may not have the funds, but trying to make the turbo you have more responsive is not only a waste of time and money, but you'll find it won't really be what you're looking for, you'll basically be restricting it with such a small rear housing and have fairly erratic power output
a garrett gt3071r or gt3076r 0.82 will both be much better suited to an rb25, in regards to power and response as a package... you won't be dissapointed
the new Garrett GTX3071r 0.82 (the 5 bolt rear garrett design, not modified copies) with correct supporting mods will see power figures of 270-300rwkw on 98ron and response of fullbost (17-19psi) by around 3600-3700rpm ... with slight modifications to the standard heatshields it can be installed to look fairly standard too!... as opposed to your externally gated 3540 which wouldn't look so standard
food for thought
https://www.sau.com.au/forums/topic/355061-hypergear/#findComment-5686503
Thanks heaps guys for your input. Definitely has given me something to think about. And yes Ruffels i do want the engine bay to look somewhat standard as the cops don't really appreciate if a external gate is right there in their face.
https://www.sau.com.au/forums/topic/355061-hypergear/#findComment-5687227
A mate with a 3540 went there, Stao have re-configured the front wheel and engineered that into a set of stock R34 turbo housings. It was heaps more responsive after its done, and looks completely stock from out side. from memory it costed just over $400.
https://www.sau.com.au/forums/topic/355061-hypergear/#findComment-5687263
That sounds like an even worse option.
I mean you cannot "reconfigure" a wheel. It's either you change it to another one or you don't.
So it wouldn't be a GT35/700hp comp wheel any more for a start, and if it still is - its TOO BIG for those housings as already stated.
Buy a turbo correctly, once. Be happy forever
https://www.sau.com.au/forums/topic/355061-hypergear/#findComment-5687286
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
