Hi,
I'm kinda new to driving and I've recently bought a Nissan Skyline R34.
Do I go to ANY Nissan store to get General Maintenance? e.g:
I can go to http://www.nissan.com.au,
click Locate a Dealer,
Enter post code, (my postcode is 2761)
then go to the nearest one ?
if so, do I also get other repairs from them? such as body crack, dent repairs, etc.
https://www.sau.com.au/forums/topic/355065-where-do-i-get-general-maintenance/
Hi welcome to SAU and it's nice to see more people like you who think outside of the garden variety falcodore square.
Firstly, Nissan Service centres won't touch grey imports.
But being in NSW, we're in luck.
With your postcode, there is a recommended service centre, repairer, tuner and engine rebuilder at Unigroup Engineering at Girraween. The man's name is Yavuz and he won't sell you anything you don't need.
For service & repair of Skylines in your/our area, there are places in
i) Peachtree Rd Penrith (name of place escapes me)
ii) Faulconbridge Automotive at Faulconbridge (ie Darren and Michael)
iii) Steve's Autobarn Blackheath (ie Steve Phillips)
These all have clients who own GT-Rs too.
Be sure to only take your car to specialist mechanics who really know skylines, there are many many horror stories of people getting fked over by their local mechanic. I took my r34 to my local mechanic for a simple clutch change, took 5 days and he cut a hole in the bell housing, simply because he didn't know how to change a pull-type clutch.
Thanks for the info!
It really saved a lot of my time trying to find one
I've visited Unigroup Engineering the other day. There was 2 other GT-Rs outside which they were working on
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
