  • Replies 216
I wish it was that simple.
It has two lots of cancer.
One in the throat and one in the brain just behind it's eye.
Because her parents are away at the moment I am at their house with my gf looking after it.
Because of the cancer in the brain, the left eye is being pushed outwards and closely resembles an extremely lazy eye.
She has started scratching at it and it started bleeding on friday morning when I got up to come to breakfast.
So being the good boyfriend that I am I took her up to the vet to see if there was anything that they could do until her parents get back tomorrow as I feel bad about putting it out of it's misery when her parents aren't here and it's their dog too.
I WILL BE AT THE NEXT ONE
  On 21/06/2011 at 12:36 AM, bubba said:
This Friday? Same bat time? Same bat place?
  On 03/06/2011 at 6:48 AM, Stinky Rooster said:
same bat time, same bat place next month?
That will be July 1st for those of you playing at home.
I cant make this week due to leaving early friday arvo.
Whoa, July 1st? You guys sure know how to pick em.
Obviously no-one works in insurance, or the financial sector in general?
June 30 is the biggest day of the financial calendar and also the biggest pissup ever.
Friday July 1st is the day when no-one gets leave, everyone is hungover and if you're late, you have to skull a pint of tomato juice with one raw egg inside for every hour late.
Something of a tradition.
But no, lunch will be at the local greasy spoon, probably a crumber chicken cheese sausage or hamburger or something.
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
