  • Replies 216
Big thanks to everyone that turned up this morning. Was a great turnout for the last feast of the year. We will leave the next one until the first Friday in February 2012, to allow paul to go on holidays.
And for those of you thinking about just turning up - just do it!
Until next year, fellow breakfasters - remember
the arteries are evil and must be punished :P
  • 1 month later...
It will def be on, even if its just me eating all the bacon, and pretty much everyone that attends has work on, thats why we have it early.
So now Phil and you have no excuse, other than laziness and apathy!
touche
Is that this friday? give details.
They sound like pretty good excuses to me!
FYI best place to park nearby for about an hour if I decide to make the holy pligremage?
come down hay st from the east end, and pretty much anywhere along the road side. Meters etc dont cut in untill 8am and we always manage to find a park close by pretty easy
Tab.....
Aaallrighty then bitches, bitchettes and Paul
Its that time of the month. Same bat time, same bat place. Who is gonna come and bask in my radiant glory.
7am
Kings Hotel
Cnr Pier and Hay st Perth
$17.50 for all you can eat - but only if you get to the bacon before El presidente
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
