  • Replies 216
Big thanks to everyone that turned up this morning. Was a great turnout for the last feast of the year. We will leave the next one until the first Friday in February 2012, to allow paul to go on holidays.
And for those of you thinking about just turning up - just do it!
Until next year, fellow breakfasters - remember
the arteries are evil and must be punished :P
  • 1 month later...
It will def be on, even if its just me eating all the bacon, and pretty much everyone that attends has work on, thats why we have it early.
So now Phil and you have no excuse, other than laziness and apathy!
touche
Is that this friday? give details.
They sound like pretty good excuses to me!
FYI best place to park nearby for about an hour if I decide to make the holy pligremage?
come down hay st from the east end, and pretty much anywhere along the road side. Meters etc dont cut in untill 8am and we always manage to find a park close by pretty easy
Tab.....
Aaallrighty then bitches, bitchettes and Paul
Its that time of the month. Same bat time, same bat place. Who is gonna come and bask in my radiant glory.
7am
Kings Hotel
Cnr Pier and Hay st Perth
$17.50 for all you can eat - but only if you get to the bacon before El presidente
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
