You have an auto turbo.
You don't have a clutch.
You never take your foot off the accelerator to change gears.
Not taking your foot off the accelerator means boost pressure will remain intact?
So you are on full boost from the first time you hit it until you let the throttle off?
  • Like 1
https://www.sau.com.au/forums/topic/355074-auto-turbos/
pretty much yeah. the downside is often autos are only 4spd or 5 spd vs manual 5spd and 6 spd. auto's often have not very performance friendly diff ratios too so that they can cruise at highway speed at low rpm and to spread the gears out a bit. but year basically a good 5spd auto, with shift kit, valvebody upgrade, high stall etc is bloody quick down the qtr mile. where they are fked is on circuit or on the road where you want to be able to pick the gear you are about to need. no auto can predict that.
https://www.sau.com.au/forums/topic/355074-auto-turbos/#findComment-5686161
Ye but even if you do pick a gear, if it's shift kitted - I've seem cars get some nasty compression lockup.
Where in a manual, in the hills etc. You can just rev-match your downshift.
AUTO certainly has its place in the 1/4 derby and you can almost continually do identical times over and over off a transbrake etc.
Where a manual requires everything to be set from RPM to clutch to driver.
If you want 1/4mile and just that - auto with a nice stall/transbrake is win.
For everything else, it's manual.
Think about it though.
A built/manualised auto and so on to run 10's with = 2.5-3k
Manual RB25 box - 1200
Factory autos do not cut it at all. Have thier place either way.
https://www.sau.com.au/forums/topic/355074-auto-turbos/#findComment-5686444
Interestingly one of the local track weapon (bendy stuff!) street cars where I live is an auto Supra with BPU, suspension, good semis and brake pads!
Yep, auto supras (turbo) with the right mods can be a damn fun thing.
The manual control option on those boxes is handy aswel.
https://www.sau.com.au/forums/topic/355074-auto-turbos/#findComment-5686788
I love my auto turbo, if I need to overtake anything I just change lanes & put foot down & the car does the rest... :whistling:
Also from what I know there was a 5 speed auto box that was available for N/A GTS Skylines? Why did they put a 5 speed (I presume its better) in N/A while gave all the GTS-Ts a old 4 speed?
https://www.sau.com.au/forums/topic/355074-auto-turbos/#findComment-5686943
5 vs 4 was for power spread. The N/A makes less power and needs the extra gear to get the power and torque optimised for it. The turbo has more and a much broader power and torque curve all round so can stay in the sweet spot much easier. And that is generally always the reason for extra gears no matter what the vehicle - and also the marketing advantage.
https://www.sau.com.au/forums/topic/355074-auto-turbos/#findComment-5687015
this is true - in addition you can also fit much larger clutch plates in a 4-speed than you can a 5 speed. increases the area of friction.
i have an RE505RA box in my stagea pushing 230awkw. with just a shift kit and a trans cooler it holds the power pretty well in fact. and personally i would rather the tiptronic auto as you can have almost as much fun in this as a manual - and as its my daily, traffic is a nightmare..
but 19.5 PSI with no drop through the gears, definitely has R8's and F6 Typhoons - even some jap cars - asking what the f**k is that?!
and mine has no compression lock, it drops when you want it to - you just have to pick the right time.
Only problem is the gear ratios - our 3rd is like a GTR's 4th.
https://www.sau.com.au/forums/topic/355074-auto-turbos/#findComment-5687039
picking the right time is a problem though. you dont want it to just suddenly go back a gear on the limit in the wet mid corner.
https://www.sau.com.au/forums/topic/355074-auto-turbos/#findComment-5687518
yep with auto you are at the mercy of the box choosing the gear for you, often delayed
but it does have advantages as other have said, no throttle body close on gearchange is same as flat shifting, constant pressure
https://www.sau.com.au/forums/topic/355074-auto-turbos/#findComment-5687553
My car isn't an auto, but I've driven auto cars before... Is this actually ever a problem? I've never had it happen to me. Surely you have a feel for what your car is doing, dropping back a gear isn't going to be a problem if you're not on WOT? If it drops back mid corner then just lift off the throttle. I dunno about you but I'm never going around corners so fast in the wet that if I dropped it back a gear I would be limiter bashing...
https://www.sau.com.au/forums/topic/355074-auto-turbos/#findComment-5687560
once you get back on the power it might...autos do funny things when getting on off the throttle/trying to hold a gear etc
https://www.sau.com.au/forums/topic/355074-auto-turbos/#findComment-5687567
it only drops depending on the speed your doing. trans ecu wont let the gear drop if your going to fast
but if you know your car, you'll know when to drop a gear, eliminates the problem.
https://www.sau.com.au/forums/topic/355074-auto-turbos/#findComment-5687579
+11ty
Also, I hate autos but this tiptronic is pretty nice, unless teh car is cold on the way to work I'm always in tiptronic and you select the gear you want when you want. The only downside is occaisionally you're going just a little too fast to put it in 1st (and it's laggy as hell exiting a corner in 2nd with a highflow and no VCT).
https://www.sau.com.au/forums/topic/355074-auto-turbos/#findComment-5687640
+11ty
my Soarer is the same....no grunt below 3000rpm + long geared 4sp auto = f**king slow in traffic
Bring on the manual conversion lol
https://www.sau.com.au/forums/topic/355074-auto-turbos/#findComment-5687659
