For sale is my R33 GTST series 2 '95/'95
Mods:
- Forward facing plenum
- 90mm TB
- Front mount intercooler
- Malpassi Rising rate fuel regulator
- 52mm dual core Aluminium radiator
- Twin Au electric thermo fans in shroud mounted
- Plumb back blow off valve
- Apexi 3 inch exhaust system
- High flow 3 inch cat converter
- 3inch dump pipe
- Volk racing rims
- Do Luck Body kit (Front bar and rear bar fitted, side skirts supplied but not fitted as yet)
- Short shift kit fitted to the gear box
- Profec B Spec 2 boost controller installed (mounted inside front ashtray so it is completely hidden when closed)
The car comes with
- A spare stock bonnet (previous owner has cut a hole in it to accomodate large cooler piping running over the top of the engine) - good for the track.
- A spare fibreglass bonnet with some damage/wear on the points at the rear/windscreen area.
- The stock intake plenum (if wanted)
- A pair of stock rims
- A pair of aftermarket rims (17inch in dark gunmetal grey)
- A spare alternator
Asking price is $8,000.00 I am open to offers however.
The car itself needs paint and a new bonnet to make it a $10-$11k car.
Feel free to ask any questions or for more pics.
I am located on the northside of Brisbane. Cheers.
https://www.sau.com.au/forums/topic/355095-fs-r33-gtst-9495-series-2/
The car is a '95 model.
You are correct '96 had the series 2's.
This car was a rolling shell when I purchased in December of 2009. With series 2 wiring in it.
Ive since put another series 2 into it. The engine I put in had 5,000 less kilometers than the odometer at the time. So the pic of the odometer is actually 5000 kilometers more than the engine in at the moment. (much of a muchness really).
Not looking to deceive anyone with a '95 series 2. Just stating what I'm selling :D.
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
