unfortunately plans have changed and i can't be driving the skylines my whole life :(
To much regret, I am selling my pride and joy, 1999 R34 GTT.
It's a stock car as far as engine mods go, but does have some nice handling parts and other parts that make this Skyline stand out from the rest. She really does turn heads whenever Im out.
R34 GTT with GENUINE NISSAN GTR Options including factory GTR adjustable Bilstein Suspension, Nismo 320km/h dash, front GTR V-spec; bumper, front lip, rear bumper and side skirts.
Front Recaro Driver Seat
Recent major service, new timing belt, drive belts, coolant, brake fluid, diff fluid, gearbox fluid, engine oil CHRONO 300V 10W40, turbo gaskets and exhaust gaskets, castor bushes, fuel filter, new split fire coil packs, new front federal 595's
ALL I USE ARE MOTUL OILS PERIOD
serviced every 5000kms by wardwhile motors
Additionally full HKS exhaust system(not loud), LED rear tail lights, front factory option xenon headlights,QFM high performance pads, Pioneer DVD head Unit with ipod connector, Tinted windows, Nismo Carbon Window trimming, cusco rear strut bar, pod filter, front mount intercooler
An unfortunate sale, buying a house so need to downgrade. Looking for a car that i can tow, with about 5-10k cash my way.
17k without rwc, 18k with rwc.
sms me please
david
0400552258
suburb doncaster
105,000kms
photos
http://www.carsales.com.au/all-cars/private/details.aspx?R=9849567&__Ntt=whc468&__Qpb=true&__Dx=mode matchany&__Ns=pCar_RankSort_Int32|1||pCar_PriceSort_Decimal|1||pCar_Make_String|0||pCar_Model_String|0&keywords=whc468&__N=1216 1247 1252 1282&__Ntx=mode matchallpartial&seot=1&__Ntk=CarAll&silo=1011&Cr=0&__Nne=15&trecs=1&__D=whc468&__sid=12E02A4918CE
https://www.sau.com.au/forums/topic/355119-vic-1999-r34-gtt-white-swapsell/
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
