Hey Guys,
My Timing belt tensioner snapped and now all the valves are bent, the stems dont look that thick, I was thinking just Multigrips and bend them back?
Nah these are off my housemates R33 that I managed to break while I took it for a little squirt to the shops because my WRX was getting painted :(
Just thought I'd share the pics.
https://www.sau.com.au/forums/topic/355149-bent-valves/
not too bad, new valves and you are back in business. Just find a stuffed second hand head with good valves.
Probably cost you about $300 (And the cost of valves) at a head re-conditioner. What are the tops of the pistons like?
https://www.sau.com.au/forums/topic/355149-bent-valves/#findComment-5687199
Tiny little mark where the vavles hit, didn't even scratch it really, just cleaned it a little, so small it doesn't even come up in the photos.
https://www.sau.com.au/forums/topic/355149-bent-valves/#findComment-5687207
lol @ bending them back - come on man...
You need to go buy new ones and then ensure they are all fitted correctly it.
If you are not doing the work yourself, its gonna get expensive.
Also as the pistsons have hit the valves, is there any score/marking on them?
https://www.sau.com.au/forums/topic/355149-bent-valves/#findComment-5687257
guys, I'm pretty sure he's joking..... but 100% it will need new valves (it would be near impossible to bend them back correctly). and probably new valve guides and valve stem seals too. that is of course providing there's no piston damage etc.
https://www.sau.com.au/forums/topic/355149-bent-valves/#findComment-5687602
bend them back, just be carefull with the exhaust valves as i think they are filled with sodium and that shit hurts if it gets in your eyes.
fill in the holes in the piston crowns with metal putty. As a bonus you can use a bit extra to raise the static compression if you have some left over.
https://www.sau.com.au/forums/topic/355149-bent-valves/#findComment-5687756
:stupid:
https://www.sau.com.au/forums/topic/355149-bent-valves/#findComment-5687831
First I lol'd at the thread title and everyone in the office looked at me.
Then I spat my drink out laughing when I got to this part:
Im still recovering....
That's all I have to add.
https://www.sau.com.au/forums/topic/355149-bent-valves/#findComment-5688137
he owns a WRX, that sounds like its been in a ding... My bets on he is serious :rofl:
+1 to badhairdave, solution made of win!
https://www.sau.com.au/forums/topic/355149-bent-valves/#findComment-5688179
Ah, that must be where that old saying comes from "dont bend valves with your eyes" :blink:
Wait... what?
https://www.sau.com.au/forums/topic/355149-bent-valves/#findComment-5688556
You could try cutting the valve stems where they are bent, then sticky taping shaped pop sticks to replace whats missing. That should fix your problem, and add 15-20rwkw.
Hey Guys,
https://www.sau.com.au/forums/topic/355149-bent-valves/#findComment-5688640
    • I've sent JaseR33 a private message in the hope he gets an email and contacts you
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
