engine is under 2000km old
Maatouk built rb26 long engine
custom rods
custom pistons
ati balancer
jun oil pump
arp head and main studs
crank treated
extensive head work
trust extended sump with pick up
engine made 694rwhp on 28psi with a t51r
call for full details
$10500 less than half of the cost to build it remembering the parts in this engine are top shelf. Built properly from day 1.
engine will make over 750rwhp with more boost, anthony stopped tuning it as the waste gate spring couldnt hold any more boost. Will hold 40+psi on e85 or c16
julian 0434778285
prepped standard block, the car was making full boost with a 35/40 at 3300rpm came on with the bigger turbo around the 4000rpm and was at 28psi around the 5000rpm, snappy set up
selling cause im stepping up to my 3L to make over 1000 to the treads
A very interesting set up.
Do you have recepits for the build and all the items that
were purchased?
i can do you one better and pull the head and sump off and show you, though i do have receipts for pretty much everything..
if youre keen give me a call and discuss
If you're going to pull the head and sump off, would you been keen on selling the short block while it's all apart? lol
yes i will separate the short block 100% as i can sell the head in 2 seconds..
$7500 and the short block is yours!!! if youre keen let me know asap.
if youre going to take the short block, make sure you make it work!!!!!!!!!!!!!!!!!! give the f**ker 40 pounds and 1000hp to huff over!
thanks
im allocating time on monday to meet at maatouks workshop to inspect the engine, may be sold pending a deposit but for those keen, please call me and organise a time on monday to go over it.
thanks
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
