Wanted: Few R33 Bits
DC33VN
 Share
Im after the following parts:
- Boot trim that covers the battery
- Radiator fan
- Front strut brace
- 1x Screw that hold the coolant bottle in place
- Plastic piece that surrounds the lock in the boot
- 1x Driver door card
- Front series 2 bonnet in white
- Gear stick leather boot( the leather on the stick)
- stock r33 gtst rim with good rubber
Would prefer someone in Sydney but interstate will be fine with the little bits.
Shoot me a pm with your price and i shall get back to you
- Radiator fan
- Front strut brace
i goy boot trim and bolt for coolent bottle and boot lock... u need the lock with nissan bit that flaps up ??? shoot me a text im in geelong vic. 0425717785. i will send that for you if ya like
- Radiator fan
- Front strut brace
- Radiator fan
- Front strut brace
ADDED
- r33 gtr rear seats
- Radiator fan
- Front strut brace
ADDED
- Radiator fan
- Front strut brace
ADDED
- Radiator fan
- Front strut brace
 Share
    • Great to know! The guys from The Skyline Shed are going to sort it out and send what I ordered anyway. Turns out their supplier sent them the wrong stock.  But it's good to know I "can" put this in if needed
    • You do not need an LSD oil in any stock (non-GTR) diff, even if it is an "LSD". This because none of the (non-GTR) LSDs are clutch/friction type LSDs. Either viscous or helical - neither of which require an LSD oil.
    • Hi everyone, I bought the Redline diff oil and the seller has sent me Redline 75W90NS even though that’s not what’s pictured.  I’ve already booked a hoist to go and change my diff tomorrow but I’m not sure if the NS is ok for the rear diff in a R34 GTT I think the NS does not have any slip modifiers so would that be an issue?    thanks in advance
    • Not easy to find pics from 15 years ago, but here is a partial one. Keep in mind that it curved immediately from the airbox, then kept a straight line for the MAF to read correctly, followed by a 45 degree bend straight down to the turbo. This connection was the most difficult as it had to twist as well as bend to meet the almost vertical straight section of the intake.
    • Yes, well, wrt a wheel alignment, there are two types. Either: You have very little added adjustables, in which case the alignment can be done by anyone in any tyre shop or equivalent, and will only take 30 minutes, and so there is no reason to even consider leaving the car there. OR: The alignment is a major exercise because you have adjustables everywhere and so you will need to be taking it to a shop that is skilled and experienced at setting up race cars and the like, and you won't need to worry about leaving the car there.
