Leithy Posted February 25, 2011 Share Posted February 25, 2011 Hi just about the Power FC D-Jetro that Nengun have on there website. just wanna know if anyone has put it in there R33 and tuned good in Australia? it doesn't run AFM so really wanna know if older Power FC has better results than this that runs map sensor Link to comment https://www.sau.com.au/forums/topic/355253-rb25-power-fc-d-jetro/ Share on other sites More sharing options...
paulr33 Posted February 25, 2011 Share Posted February 25, 2011 im yet to know of anyone who has purchased this, if you do, i would be keen to check it out it should make 0rwkw more than the AFM version as the sensor does not make or restrict power Link to comment https://www.sau.com.au/forums/topic/355253-rb25-power-fc-d-jetro/#findComment-5688861 Share on other sites More sharing options...
89CAL Posted February 26, 2011 Share Posted February 26, 2011 are these essentially a 26 d-jetro converted to plug straight into a 25 (so no vct) or are they designed to work like the standard power FC for the RB25 but with the option for MAP sensor etc?? Link to comment https://www.sau.com.au/forums/topic/355253-rb25-power-fc-d-jetro/#findComment-5689170 Share on other sites More sharing options...
paulr33 Posted February 26, 2011 Share Posted February 26, 2011 based on the info from nengun its BCNR33 remapped by apexi to suit RB25 with djetro kit so VCT should work if you buy it id be interested in checking it out either in flesh (vic) or photos the kit comes with remapped BCNR33 powerfc djetro map sensor map sensor loom temperature sensor boomslang adapter (cos it must covert native ECR33 loom to BCNR33 loom) so be aware you'll have a boomslang / field one touch patch kit loom as well kinda handy if u want to install other staff, but also adds to the cost Link to comment https://www.sau.com.au/forums/topic/355253-rb25-power-fc-d-jetro/#findComment-5689211 Share on other sites More sharing options...
89CAL Posted February 26, 2011 Share Posted February 26, 2011 I've just emailed them about it. Pretty doubtful I will spend that money on something I esentially already have, but will see what the response says. Just wanted to confirm some of the above. I wasnt sure what the last 2 products are in the kit as only product codes are listed, no description And are you talking about the CN-2 One-touch connector as the "boomsling" harness Paul? Link to comment https://www.sau.com.au/forums/topic/355253-rb25-power-fc-d-jetro/#findComment-5689231 Share on other sites More sharing options...
paulr33 Posted February 26, 2011 Share Posted February 26, 2011 the last part # is the air temp sensor but its weird as it includes a mazda map sensor and the boost control kit map sensor and loom so its like the kit comes with the boost kit too, so im not sure on that one i would believe it when i saw it, but it does sound odd you get both map sensors - maybe the description is wrong Link to comment https://www.sau.com.au/forums/topic/355253-rb25-power-fc-d-jetro/#findComment-5689248 Share on other sites More sharing options...
paulr33 Posted February 26, 2011 Share Posted February 26, 2011 yeah cn-2 one touch is the same as a boomslang loom patch kit, same product basically lets them plug OEM ECR33 and then flip wires around etc to mate up with BCNR33 as its same stocket on each end and lets you do whatever you want on the wiring loom without making the user hack or solder their own loom Link to comment https://www.sau.com.au/forums/topic/355253-rb25-power-fc-d-jetro/#findComment-5689251 Share on other sites More sharing options...
89CAL Posted February 26, 2011 Share Posted February 26, 2011 yeah thats fair enough. Does this mean that the Power FC has provisions for a 26 loom and the boomslang adapts it to 25. Or other way around, Power FC has 25 connector and the boomslang is for plugging it into a 26 loom Get the point of the harness just unsure which way around it actually is Link to comment https://www.sau.com.au/forums/topic/355253-rb25-power-fc-d-jetro/#findComment-5689268 Share on other sites More sharing options...
paulr33 Posted February 26, 2011 Share Posted February 26, 2011 no it works like this the powerfc you are buying is BCNR33 powerfc the plug on that powerfc is the same as ECR33 powerfc BUT your car has ECR33 loom which means it will plug in, but some of the wires are reversed and different so if you were to plug in BCNR33 to ECR33 car it would probably short out or not work (worst case blow fuses, short out) so in order to make it safely connect and all the sensors match you use an inline patch kit and on the patch connector you make wire changes, ie flip wires, swap around, and in some cases, remove wires too so your powerfc still remains a legit BCNR33 Powerfc the loom does all the hard wire work and then it connects to ECR33 loom without the boomslang patch kit or one-touch connector before installing the BCNR33 powerfc you would have to cut wires, flip wires around etc the plug is the same, but if you installed it, didnt do the wiring correctly and keyd-on it would either not work or fry shit BCNR33 POWERFC ---> boom slang patch kit (with wire changes) ----> ECR33 loom plug under carpet stock ecu ------> ECR33 loom plug under carpet i tried to do what nengun has done here and the Mafia got it working ( i was too scared ) and cubes did it as well they did it with std powerfc and not djetro Link to comment https://www.sau.com.au/forums/topic/355253-rb25-power-fc-d-jetro/#findComment-5689329 Share on other sites More sharing options...
89CAL Posted February 26, 2011 Share Posted February 26, 2011 ah yeah makes sense now. Well made sense before but now I actually know what the deal is Yeah will see what they come back with in the email. Asked them about the two extra parts at the end and if it did run the VCT etc as if it were a normal RB25 power fc. I might be interesting in getting one, but will have to weigh up costs etc. As you said it wont really get me any gains in power, but I mainly just want to get rid of my AFM Link to comment https://www.sau.com.au/forums/topic/355253-rb25-power-fc-d-jetro/#findComment-5689863 Share on other sites More sharing options...
soturi Posted February 26, 2011 Share Posted February 26, 2011 +1 to hating afm's!!! lolol Let us all know how you go bud..im keen to know as well! Aiden Link to comment https://www.sau.com.au/forums/topic/355253-rb25-power-fc-d-jetro/#findComment-5689982 Share on other sites More sharing options...
paulr33 Posted February 26, 2011 Share Posted February 26, 2011 im interested to know if its a legit apexi remap like the ap engineering units, ie it says RB25D-1 in the VERSION string under ETC, VERSION and if you do a DATA INIT, does it return to RB26 defaults or the rb25 djetro defaults if its a legit remap it should say RB25 in the version and when you data init it should return to 25 defaults if its just a 26 djetro with a rb25 settings on the top (possible and would work) then if you check ETC, VERSION it will say RB26D and when you data init it the car probably wont start- so it will be interesting to see i cant see them selling a once off tune, it would have to be a legit remap by apexi but then if they do it (apexi do), why not let all suppliers stock it, as this is a nengun only special apparently Link to comment https://www.sau.com.au/forums/topic/355253-rb25-power-fc-d-jetro/#findComment-5689987 Share on other sites More sharing options...
89CAL Posted February 27, 2011 Share Posted February 27, 2011 Yeah I cant see how they can sell it with a special remap that disappears if you init all data. You have to do this to do the self learn, and if you got it wrong the first time you used the Power FC then your left with a unit that cant be wipped. I dunno they make it sound like its a pretty legit deal. But Will see what Nengun say. Does this mean that You will be able to add an air temp sensor and have that work on the hand controller as well etc. Im guessing that it does. If everything seems good then I may consider it. If I do end up buying one and you want a look, I'm happy to help you add some information about it to your FAQ, but I suspect someone else will buy it before me I'm suprised theres no threads on here about it...... (apart from this one of course) Link to comment https://www.sau.com.au/forums/topic/355253-rb25-power-fc-d-jetro/#findComment-5690462 Share on other sites More sharing options...
paulr33 Posted February 27, 2011 Share Posted February 27, 2011 BCNR33 has native working air temp support and it comes with the sensor on the boomslang loom or one touch loom there will be an extra wire for the air temp sensor youll need to tap and drill out a bung in the intercooler pipework somewhere for the sensor (its identical to the water temp sensor, same part #) and then fit that and run its signal wire onto the loom. the kit should come with instructions (i would like to see these) to show you where to wire that signal wire to be sure to note the airtemp correction retards timing as airtemp increases that is, its a correction used to back out timing when it has excessive intake temp (ie summer with boost) Link to comment https://www.sau.com.au/forums/topic/355253-rb25-power-fc-d-jetro/#findComment-5690619 Share on other sites More sharing options...
collins Posted October 4, 2011 Share Posted October 4, 2011 Sooooo, Anyone got one of these yet? Im about this close to buying one.. [......] Which is pretty close, before you ask.. Link to comment https://www.sau.com.au/forums/topic/355253-rb25-power-fc-d-jetro/#findComment-6044519 Share on other sites More sharing options...
89CAL Posted October 4, 2011 Share Posted October 4, 2011 (edited) Just do it If I'd got tax money I'd have one in my car right now. Just email nengun about it if you have any questions, they were pretty helpful when I asked about it BTW Paul: I did hear back from them and they said that it was a remap by a tuner (from memory) in Japan that works closely with Nengun, but if "Data Init" is performed on the unit, then it needs to be sent back to Nengun to have the tune flashed back onto it. Bit of a shame but I can see exactally why they would do this. Its not much info but might be helpful at some point when you have enough info to put in the FAQ Edited October 4, 2011 by 89CAL Link to comment https://www.sau.com.au/forums/topic/355253-rb25-power-fc-d-jetro/#findComment-6044523 Share on other sites More sharing options...
