based on the info from nengun its BCNR33 remapped by apexi to suit RB25 with djetro kit
so VCT should work
if you buy it id be interested in checking it out
either in flesh (vic) or photos
the kit comes with
remapped BCNR33 powerfc
djetro map sensor
map sensor loom
temperature sensor
boomslang adapter (cos it must covert native ECR33 loom to BCNR33 loom)
so be aware you'll have a boomslang / field one touch patch kit loom as well
kinda handy if u want to install other staff, but also adds to the cost
I've just emailed them about it. Pretty doubtful I will spend that money on something I esentially already have, but will see what the response says.
Just wanted to confirm some of the above.
I wasnt sure what the last 2 products are in the kit as only product codes are listed, no description
And are you talking about the CN-2 One-touch connector as the "boomsling" harness Paul?
the last part # is the air temp sensor
but its weird as it includes a mazda map sensor and the boost control kit map sensor and loom
so its like the kit comes with the boost kit too, so im not sure on that one
i would believe it when i saw it, but it does sound odd you get both map sensors - maybe the description is wrong
yeah cn-2 one touch is the same as a boomslang loom patch kit, same product basically
lets them plug OEM ECR33 and then flip wires around etc to mate up with BCNR33
as its same stocket on each end and lets you do whatever you want on the wiring loom without making the user hack or solder their own loom
yeah thats fair enough. Does this mean that the Power FC has provisions for a 26 loom and the boomslang adapts it to 25. Or other way around, Power FC has 25 connector and the boomslang is for plugging it into a 26 loom
Get the point of the harness just unsure which way around it actually is
no it works like this
the powerfc you are buying is BCNR33 powerfc
the plug on that powerfc is the same as ECR33 powerfc
BUT
your car has ECR33 loom
which means it will plug in, but some of the wires are reversed and different
so if you were to plug in BCNR33 to ECR33 car it would probably short out or not work (worst case blow fuses, short out)
so in order to make it safely connect and all the sensors match
you use an inline patch kit and on the patch connector you make wire changes, ie flip wires, swap around, and in some cases, remove wires too
so your powerfc still remains a legit BCNR33 Powerfc the loom does all the hard wire work and then it connects to ECR33 loom
without the boomslang patch kit or one-touch connector before installing the BCNR33 powerfc you would have to cut wires, flip wires around etc
the plug is the same, but if you installed it, didnt do the wiring correctly and keyd-on it would either not work or fry shit
BCNR33 POWERFC ---> boom slang patch kit (with wire changes) ----> ECR33 loom plug under carpet
stock ecu ------> ECR33 loom plug under carpet
i tried to do what nengun has done here and the Mafia got it working ( i was too scared ) and cubes did it as well
they did it with std powerfc and not djetro
ah yeah makes sense now. Well made sense before but now I actually know what the deal is :)
Yeah will see what they come back with in the email. Asked them about the two extra parts at the end and if it did run the VCT etc as if it were a normal RB25 power fc. I might be interesting in getting one, but will have to weigh up costs etc. As you said it wont really get me any gains in power, but I mainly just want to get rid of my AFM
im interested to know if its a legit apexi remap like the ap engineering units, ie it says RB25D-1 in the VERSION string under ETC, VERSION
and if you do a DATA INIT, does it return to RB26 defaults or the rb25 djetro defaults
if its a legit remap it should say RB25 in the version and when you data init it should return to 25 defaults
if its just a 26 djetro with a rb25 settings on the top (possible and would work) then if you check ETC, VERSION it will say RB26D and when you data init it the car probably wont start- so it will be interesting to see
i cant see them selling a once off tune, it would have to be a legit remap by apexi
but then if they do it (apexi do), why not let all suppliers stock it, as this is a nengun only special apparently
Yeah I cant see how they can sell it with a special remap that disappears if you init all data. You have to do this to do the self learn, and if you got it wrong the first time you used the Power FC then your left with a unit that cant be wipped. I dunno they make it sound like its a pretty legit deal. But Will see what Nengun say.
Does this mean that You will be able to add an air temp sensor and have that work on the hand controller as well etc. Im guessing that it does. If everything seems good then I may consider it. If I do end up buying one and you want a look, I'm happy to help you add some information about it to your FAQ, but I suspect someone else will buy it before me
I'm suprised theres no threads on here about it...... (apart from this one of course)
BCNR33 has native working air temp support and it comes with the sensor
on the boomslang loom or one touch loom there will be an extra wire for the air temp sensor
youll need to tap and drill out a bung in the intercooler pipework somewhere for the sensor (its identical to the water temp sensor, same part #) and then fit that and run its signal wire onto the loom. the kit should come with instructions (i would like to see these) to show you where to wire that signal wire to
be sure to note the airtemp correction retards timing as airtemp increases
that is, its a correction used to back out timing when it has excessive intake temp (ie summer with boost)
  • 7 months later...
Just do it
If I'd got tax money I'd have one in my car right now. Just email nengun about it if you have any questions, they were pretty helpful when I asked about it
BTW Paul: I did hear back from them and they said that it was a remap by a tuner (from memory) in Japan that works closely with Nengun, but if "Data Init" is performed on the unit, then it needs to be sent back to Nengun to have the tune flashed back onto it. Bit of a shame but I can see exactally why they would do this. Its not much info but might be helpful at some point when you have enough info to put in the FAQ
Edited by 89CAL
