Hi Guys,
Since owning this beauty I have struggled to use it for what it was intended, a few track days and some fun. I havent been able to do so for a few reasons, tracking a car of this quality I thought was crazy, as well as have no time and lost some motivation for such a hobby.
This is an EOI as I LOVE the car and will only sell at the right price.The car has had a lot of rubbers, door trims etc replaced in the 2004 rebuild in Japan and feels like a new car, no squeeks or rattles at all:)
Having owned a few GTRs through the years this is without a doubt, by far the best build and performing GTR I have had, hence not too fussed if it sells!
Year: 1989
Body: 2 Door Coupe
Colour: Pearl Wine Red
Engine: 2.6L Twin Turbo, Twin Cam Inline 6 Cylinder (RB26DETT)
Transmission: 4WD MT
Odometer: 32,000kms (engine specific)
Price: $29,500 with RWC
Contact Details: 0401-004-999
Comments: Below is the modification list along with some history on the car, photos follow afterwards.
:: Engine ::
- Brand new R33 RB26DETT N1 Engine, only done around 32,000kms
- Brand new R34 N1 Twin Turbos, same mileage as new engine
- Greddy adjustable Cam Gears with clear cam gear cover (comes with original cover as well, see pic with extra parts)
- Sard 800cc Injectors
- HKS Drag Intercooler (600x300x100mm ? LxWxD, tube & fin design), 3? Inlet / Outlet
- Custom 3? Intercooler Piping
- Custom 3.5? mandrel Exhaust System from turbos to 4.5? rear muffler - amazingly subdued off boost but sounds great on full boost, very angry and tough. System is quiet easy on the ears as well with zero drone.
- Oil cooler with air guide and remote oil filter for easy replacement
- Oil Catch Can
- Twin Apexi Pod Filters
- Apexi Power FC ECU (tuned by Ben @ Racepace on 20psi = 320awkw )
:: Drive Train / Brakes ::
- Standard two piece drive shaft, LSD and 4WD system all very tight and strong ? never had any problems running current power for the last 3 years of ownership.
- Jim Berry ?Full Monty? single plate carbonetic clutch, 3600lbs pressure plate matched to an R31 Fly Wheel ? beautiful clutch, never had it slip on me once with current power level and operates almost like a standard clutch in terms of pedal heaviness and driveability in traffic.
- VSpec 2 Brembo front callipers with Lockheed rotors and pads, standard rear callipers and rotors / pads ? pulls up exceptionally well, feels like your eyeballs will pop out and its still got more in it before the ABS even kicks in!
- Teflon braided brake lines
:: Suspension / Bracing / Wheels ::
- Tein Coilovers, adjustable stiffness and dampening
- 11 structural bracing bars:
--- 2 Front & Rear Strut Braces
--- 1 Interior Cabin Brace (per image)
--- 4 Front & Rear Guard Braces (1 under each guard running lengthwise)
--- 1 Brace underneath near rear of engine / front of gearbox
--- 1 Mid trans tunnel Brace connecting either side of the tunnel
--- 2 Rear subframe Braces (1 each side)
- Volk Racing CE28N 17x9? Forged Monoblock lightweight Wheels (includes VR Duraluminium wheel nuts and VR valve caps) This combination of stiffness and grip makes for a very flat and stable cornering attitude with great response from the tyres under braking, cornering and acceleration.
:: Exterior / Interior ::
- Lightweight fibreglass bonnet
- Aerocatch Bonnet Pins (lockable)
- N1 Side Skirts & Vents in front bar
- Momo ?Race? Steering Wheel
- GTR carbon fibre Gear Knob
- Apexi EL2 Mechanical Boost Gauge
- Nismo 320kmph Speedometer
- Kenwood CD / MP3 head unit with what looks like standard speakers front & back - Fire extinguisher mounted to rear cabin brace
- Original Nissan GTR floor mats front & back with the original flare case in the front passengers foot well
- Original Nissan GTR front & rear seats in excellent, nearly as new condition - bolsters still all firm & solid, top of rear seats are not faded like nearly all other R32s are.
- All dash & trim in excellent condition with all accessories, gauges & lights fully functional - heater & aircon work as good as the day it rolled off the factory floor, only problem is there must be a dry solder inside the climate control unit that causes the display to turn off randomly, a light tap on the front brings it back. It doesn?t effect functionality of the climate control system itself or the manual button controls, it?s a common fault you?ll find in a lot of R32s, easily fixable if you have the time to pull it out and take to an autoelec.
:: History ::
The car was originally gunmetal grey before the owner of it then in Japan did a ground up rebuild of the car in 2004. It was resprayed a metallic factory colour ?wine red? but with lots of pearl and the engine bay was sprayed a stark white, maybe to show off the engine or to show up leaks and issues a lot easier?either way you always get asked the question when popping the bonnet ?did it use to be white??. The only place you can still see the original colour is the rear strut towers.
This chap worked at Nissan in Japan and so had access to many new parts for the GTR and is why you?ll find a lot of the seals and small plastic parts are like new as well as a lot of engine bay components.
Basically from there he dropped in the new motor and turbos with most of the listed supporting mods, the only mods added in Australia were the injectors, adjustable cam gears and the boost gauge.
A bloke well known in the NDSOC (Nissan Datsun Sports Owner Club) association imported it for himself in 2005 and owned it for a little over a year, taking it to a few show n? shines and concourse events.
:: General Info ::
- I have always kept it garaged and drive it as a daily driver with low KMs.
- Fastidiously maintained, never parked at shopping centres or with general cars as it has not one dent.
- Oil services have always been done every 5,000kms, quite often less and always with a new filter.
Please find the pictures below, I have really focused on what may seem obscure detail in some shots but it is to show the quality and condition the car has been kept in.
Cheers!
Jamie
Edited by glaze
  • Replies 48
Posted Images
Am Negotiable on price and happy to look into trades, but please, no more 2 door sports cars.
Lexus IS200's, 2000 Stock WRX or FPV's & HSV's will be looked at. Hopefully that will chop back the emails and Txt messages:)
After driving this car the past few days and getting Txt msgs with lowball offers around the $23-$25K mark, I have decided that the price of $29,500 is set, I will only neg slightly on price face to face with interested parties upon inspection. Please do not Txt me an offer, come to a look for yourself as pics do not do this car justice!!!
Thx
Just thought I would let you know that I will be away for 2 weeks as of tomorrow and can be reached via PM.
I have a few interested parties looking to view/test when I get back, so if you want this car be quick. Am looking at offers of $28K+ only at the moment.
Thanks
Bump.
Gettingback to Australia on Wednesday for interested parties to view. I have a older guy possibly getting a test done on Saturday, so if you want to come check this out, do so ASAP!
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
