Hi Guys,
Since owning this beauty I have struggled to use it for what it was intended, a few track days and some fun. I havent been able to do so for a few reasons, tracking a car of this quality I thought was crazy, as well as have no time and lost some motivation for such a hobby.
This is an EOI as I LOVE the car and will only sell at the right price.The car has had a lot of rubbers, door trims etc replaced in the 2004 rebuild in Japan and feels like a new car, no squeeks or rattles at all:)
Having owned a few GTRs through the years this is without a doubt, by far the best build and performing GTR I have had, hence not too fussed if it sells!
Year: 1989
Body: 2 Door Coupe
Colour: Pearl Wine Red
Engine: 2.6L Twin Turbo, Twin Cam Inline 6 Cylinder (RB26DETT)
Transmission: 4WD MT
Odometer: 32,000kms (engine specific)
Price: $29,500 with RWC
Contact Details: 0401-004-999
Comments: Below is the modification list along with some history on the car, photos follow afterwards.
:: Engine ::
- Brand new R33 RB26DETT N1 Engine, only done around 32,000kms
- Brand new R34 N1 Twin Turbos, same mileage as new engine
- Greddy adjustable Cam Gears with clear cam gear cover (comes with original cover as well, see pic with extra parts)
- Sard 800cc Injectors
- HKS Drag Intercooler (600x300x100mm ? LxWxD, tube & fin design), 3? Inlet / Outlet
- Custom 3? Intercooler Piping
- Custom 3.5? mandrel Exhaust System from turbos to 4.5? rear muffler - amazingly subdued off boost but sounds great on full boost, very angry and tough. System is quiet easy on the ears as well with zero drone.
- Oil cooler with air guide and remote oil filter for easy replacement
- Oil Catch Can
- Twin Apexi Pod Filters
- Apexi Power FC ECU (tuned by Ben @ Racepace on 20psi = 320awkw )
:: Drive Train / Brakes ::
- Standard two piece drive shaft, LSD and 4WD system all very tight and strong ? never had any problems running current power for the last 3 years of ownership.
- Jim Berry ?Full Monty? single plate carbonetic clutch, 3600lbs pressure plate matched to an R31 Fly Wheel ? beautiful clutch, never had it slip on me once with current power level and operates almost like a standard clutch in terms of pedal heaviness and driveability in traffic.
- VSpec 2 Brembo front callipers with Lockheed rotors and pads, standard rear callipers and rotors / pads ? pulls up exceptionally well, feels like your eyeballs will pop out and its still got more in it before the ABS even kicks in!
- Teflon braided brake lines
:: Suspension / Bracing / Wheels ::
- Tein Coilovers, adjustable stiffness and dampening
- 11 structural bracing bars:
--- 2 Front & Rear Strut Braces
--- 1 Interior Cabin Brace (per image)
--- 4 Front & Rear Guard Braces (1 under each guard running lengthwise)
--- 1 Brace underneath near rear of engine / front of gearbox
--- 1 Mid trans tunnel Brace connecting either side of the tunnel
--- 2 Rear subframe Braces (1 each side)
- Volk Racing CE28N 17x9? Forged Monoblock lightweight Wheels (includes VR Duraluminium wheel nuts and VR valve caps) This combination of stiffness and grip makes for a very flat and stable cornering attitude with great response from the tyres under braking, cornering and acceleration.
:: Exterior / Interior ::
- Lightweight fibreglass bonnet
- Aerocatch Bonnet Pins (lockable)
- N1 Side Skirts & Vents in front bar
- Momo ?Race? Steering Wheel
- GTR carbon fibre Gear Knob
- Apexi EL2 Mechanical Boost Gauge
- Nismo 320kmph Speedometer
- Kenwood CD / MP3 head unit with what looks like standard speakers front & back - Fire extinguisher mounted to rear cabin brace
- Original Nissan GTR floor mats front & back with the original flare case in the front passengers foot well
- Original Nissan GTR front & rear seats in excellent, nearly as new condition - bolsters still all firm & solid, top of rear seats are not faded like nearly all other R32s are.
- All dash & trim in excellent condition with all accessories, gauges & lights fully functional - heater & aircon work as good as the day it rolled off the factory floor, only problem is there must be a dry solder inside the climate control unit that causes the display to turn off randomly, a light tap on the front brings it back. It doesn?t effect functionality of the climate control system itself or the manual button controls, it?s a common fault you?ll find in a lot of R32s, easily fixable if you have the time to pull it out and take to an autoelec.
:: History ::
The car was originally gunmetal grey before the owner of it then in Japan did a ground up rebuild of the car in 2004. It was resprayed a metallic factory colour ?wine red? but with lots of pearl and the engine bay was sprayed a stark white, maybe to show off the engine or to show up leaks and issues a lot easier?either way you always get asked the question when popping the bonnet ?did it use to be white??. The only place you can still see the original colour is the rear strut towers.
This chap worked at Nissan in Japan and so had access to many new parts for the GTR and is why you?ll find a lot of the seals and small plastic parts are like new as well as a lot of engine bay components.
Basically from there he dropped in the new motor and turbos with most of the listed supporting mods, the only mods added in Australia were the injectors, adjustable cam gears and the boost gauge.
A bloke well known in the NDSOC (Nissan Datsun Sports Owner Club) association imported it for himself in 2005 and owned it for a little over a year, taking it to a few show n? shines and concourse events.
:: General Info ::
- I have always kept it garaged and drive it as a daily driver with low KMs.
- Fastidiously maintained, never parked at shopping centres or with general cars as it has not one dent.
- Oil services have always been done every 5,000kms, quite often less and always with a new filter.
Please find the pictures below, I have really focused on what may seem obscure detail in some shots but it is to show the quality and condition the car has been kept in.
Cheers!
Jamie
Edited by glaze
  • Replies 48
Posted Images
Am Negotiable on price and happy to look into trades, but please, no more 2 door sports cars.
Lexus IS200's, 2000 Stock WRX or FPV's & HSV's will be looked at. Hopefully that will chop back the emails and Txt messages:)
After driving this car the past few days and getting Txt msgs with lowball offers around the $23-$25K mark, I have decided that the price of $29,500 is set, I will only neg slightly on price face to face with interested parties upon inspection. Please do not Txt me an offer, come to a look for yourself as pics do not do this car justice!!!
Thx
Just thought I would let you know that I will be away for 2 weeks as of tomorrow and can be reached via PM.
I have a few interested parties looking to view/test when I get back, so if you want this car be quick. Am looking at offers of $28K+ only at the moment.
Thanks
Bump.
Gettingback to Australia on Wednesday for interested parties to view. I have a older guy possibly getting a test done on Saturday, so if you want to come check this out, do so ASAP!
    • You’ll want to have the block drilled and tapped to suit 1/2in head studs and the head for the same. How much power do you intend to make?
    • Sorry for resurrecting an oldish thread Not much has happened in the past year since the last update. The car did another 1000 miles or so and failed the MOT for the first time in October (failed on tyres which had been advised for a couple of years) In October the car got put up for sale and was removed in November due to no interest, being so close to christmas it was to be expected. The roads were dry in February so I decided to tax it early and get the new tyres fitted.   Fast forward to April, I got someone in to give the car a good clean after sitting for the winter.                                 The car got re-advertised and today (Saturday 3rd May) the car sold. The new owner is planning a GTR conversion at some point and a respray in the same pearl white. It's bitter sweet, it's a shame to have the car sit there for half the year and then only do 1000 miles. The kids are growing too quick and space in the back is getting limited. It's been a great 6.5 years of ownership
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
