  • Replies 129
Guest INASNT
You wanna know how to shut him up? It's like the espisode of the simpsons where all the giant billboard characters came to life, don't pay them attention and they crawl back to the rock they came from. Give it a go hey???
:sadam:
Sounds like a plan.
I think Merli has gone off to do his weekend job as a parking inspector.
just got back from the F1 GP.... Corprate Box Pit lane Exit Stand to see this thread is still going.. rolf. Some mean a$$ pics.. I'll post'em up once developed. PS: And I mean some mean A$$'s :)
So? Hate to burst your bubble corprate boy but I've been sitting in race controll most of the day.....Does anyone care? No....
well if i were in melb iwould have a good seat for F1... have penthouse at 582 st kilda road.. but stuck in shitty qld..
anyway, to add my bit.. it sounds like these NSW guys never get pulled over? And also, sounds like u all have never driven without a license.. funny how I have a mate whos a paramedic with no license currently.. bet if you were having a heart attack you would shut the **** up pretty soon and stop bitching..
i with Merli, on this.
How can u people not think jail time is a good idea? If he had hit someone or lose controll he would have most likly kill himself which isnt the important part but kill someone else. Sorry but i have no time for people like this so what speedin in your car gives u a thrill?
Get the **** over it your not 2yrs old and arnt able 2 controll yourself.
Like merli said once i can understand, but again no way and driving when sus. is just soo ***ing stupid u r asking for troble i say u got wat u desvered.
People like YOU are the reason US HPI drivers get bad names, People Like YOU are the reason why our Insrance keeps on going up, People like You are the reason why police taget HPI
I would like 2 see how the hell you would get insurance now ahahahahaha
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
