Hey Guys,
Wasn't sure where to put this post, hopefully this is the correct section.
I'm getting my car ready for track, and I need to install a front tow hook to comply.
My front end is completely removed during my A/C removal, so now is the best time to put one on.
I have looked at the generic one's at various race shops, but they all look to short.
Has anyone here done this, is so what spec tow hook did you use and any pics of install?
Help much appreciated.
Cheers
https://www.sau.com.au/forums/topic/355367-front-tow-hook-install-fab/
hi mate, the solid tow hooks really are not the way to go unless you have to.
we just run a piece of webbing (in my case cut from the end of a tie down strap), loop it in half, put 2 grommets in it and bolt it to where the reo mounts to the chassis. then cut a small slit in the bumper about 10x4mm and pull the loop through it. just make sure the loop goes atleast 15mm past the bar
Duncan:
I was just reading a post you did a while ago in the motorsport section which illustrated your solution (with pics)
I don't need to go a a solid tow hook, it's only what I have seen around.
So the reo bar is strong enough to withstand this load?
Husky33: Where abouts did you buy the strap? revolution race gear??
Edited by GreddyGo
  • 10 months later...
  • 3 weeks later...
There was a guy on here a while ago selling tow straps in various colours. See if i can find the link for you.
EDIT: Yep it was BIT SUS
http://www.facebook.com/pages/BITSUS-Customs/123901314289451?sk=app_4949752878
Edited by dirty jew
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
    • Wow. Pissy much? You on a mission to find old posts to argue with, or is this legitimately just because you're 5 years into a 1 day job?
