20" Rims On R34 Gtr
Hi all,
can't find much on here about it, but I had a look at Enkei's fitment guide and they are saying a 19x10 +35 is best fit for an R34 GTR, I was looking to stuff a 20x10+35 in there, with a 275/30/R20.
Can anyone see a problem with this?
The rolling diameter of my stocks with 265/35R18's RE01's will be just over 3%, so no real matter philosophically there for me, I think the std ratios are a little short anyway. will have copy z-tune guards and lowered adjustable suspension and bushes to reduce cambers and help keep more tyre on the road.
these are the ones I am looking at;
those wheels are shit.
why would u put 20s on a r34 gtr?
19s are more than enough and as above said that off set will be shit,
gtrs need low off sets to look good, no more than +20 at the most
20x10 +35 WILL NOT clear the front wishbone thingy.
If U want big wheels, PLEASE consider 19's! Why did you buy an amazing performance car if you're just gonna take the performance away and rice it up?
Try and find some 19x10 +15 and get some 265/30R19's. It won't handle as well as stock wheels but is probably an acceptable compromise between performance and bling.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
