hello i have for sale a japanese ps2 . All of the games are original and are in perfect condition. the games are
Gran turismo 4 prologue
Gran turismo 3, includes the very rare logitec gran turismo steering wheel.
Gran turismo concept
initial d
Everybodies golf 3
ddr max, inc original konami mat
metal gear solid 2
beatmania 2dx 3rd style, inc controller
devil may cry
winning eleven 5
maximo
tekken tag
street fighter ex3
powerful baseball 7
Most of these games are in english . all the games are ORIGINAL and come with manaual, ill also throw in a power transformer, contoller, memory card and a few special controllers. come on people this owes me $1,600+.
im open to offers around $500 for a quick sale.
I just bought my ps2 off ebay waiting for it, if you consider splitting i would be interested in. I can only play pal/ntsc ? games. Interested in:
initial d
metal gear solid 2
devil may cry
tekken tag
street fighter ex3 btw in Sydney , thanks
i can direct debit online so you should get the money fairly quickly, btw hope the games can play on Aus systems.
Let me know what you think cause i really need some games :(
========aww shame :bs!:
Good luck with the sale anyway ;)
    • Google says for a 1998 Nissan Maxima to pull/pry, and the metal pin might even come out with it. I'd do a bit more googling, there was a few videos, find some where the shafts/needles appear most similar and compare the techniques.
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
    • I particularly like the look of the John Player Special team. (Thumbnail isn't different but hit play for the clip)
    • Such a cool collection of cars back then.
    • Mystery solved, thanks bro Bit of a strange mix, but i dont mind it, still looks good.
