2000 R34 2 Door Gt Dark Blue 104Ks Manual $3500
Hey,
Got a 2000 model skyline gt manual with the rb25de neo for sale. Car is complianced.
Got damage to front and small amount to rear. Front has hit the rad support slightly and smashed both headlights. Will need to replace front bar (may be able to be fixed, is broken along bottom, headlights, rad, fans, bonnet. Engine still runs, very small leak in radiator. Fan not touching radiator though. Has battery but is on charge atm, not sure if it is stuffed, not very old though. Front quarters are undamaged.
Chassis is all straight. Rear has also been touched, will need to replace boot lid, but spoiler is fine and bumper may be ok. Car has only done 104 ks. Has cannon muffler and apexi pod filter. Also has an alpine headunit with parrot bluetooth integrated, front usb, ipod cable connection etc worth bout $400. Please note front speakers have been removed and middle dash vent are missing. Has factory floor mats.
In decent nick, low k's, cigarette burn to rear passenger side seat base but other than that, pretty clean. Tyres are good with rears near new, has the factory rims.
The car is a repairable write off, Its just I dont have time atm to fix it! Located near Frankston, VIc. Viewing welcome. Please contact 0422641010 for more info or to see the car. Looking for quick sale, $3500.
Car will be parted out in a couple of weeks if not sold. BTW The first pic is when the car was purchased.
Edited by griffonfamily
How much money has to go into the car to get it fixed do you think?
Not sure mate, your welcome to assess the damage yourself if you like.
Final price drop to $3200! If not sold by Friday 11th , the car will be parted out so get in quick.
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
