Hey all
So today whilst driving (with my daughter in the car) at speeds of a MASSIVE 40kph I got pulled over (a common occurrence) after the old pop of the bonnet , click of the camera I now have a EPA referral :-( . He says my exhaust is too loud which I wont argue till I have facts , my front mount needs to be emissions tested and my pod filter which is under a enclosed aluminum housing (his argument is the bottom is not enclosed . Has any one had to have a EPA test for any of these 3 things ? My problem is I don't have any stock parts to change over and I imagine the wouldn't be cheap . I'm going to see what my options are regarding the dealer I bought it from because it "passed" a blue slip fitted with these things , the cop said I can write to the EPA and have them hunt down the dealer ?
https://www.sau.com.au/forums/topic/355437-cops-got-me/
bad luck there,we are all driving our liners with a fair amount of mods.So far in nearly 10 years of having a 33 i have never had pop the bonnet please,i guess being an old girl helps.I hope you get it sorted asap.Genelle. :cheers:
https://www.sau.com.au/forums/topic/355437-cops-got-me/#findComment-5690603
theres a couple of threads relating to people having these problems...its a major pain in the ass..i had a similar thing happen to me...you dont want to go for an emmisions test coz it is pretty hard to pass...you will not pass with a stock exhaust..
.best option (which i ended up having to do in the end) is just just buy/ borrow or steal standard side mount, airbox and exhaust..swap em over, go to the inspection station get it cleared and it will be sweet, its a lot of mucking around considering 99% of people will just swap it back anyway
good luck
https://www.sau.com.au/forums/topic/355437-cops-got-me/#findComment-5690645
i got EPA for noise, your car will NEED to be at or under 90 DB at 4,700 RPM. i went to the bloke at granville, he was a knob and failed me first time due the the silencer in my cannon not being fully welded and "part" of the exhaust. i came in at 90 db.
Metal flange piece and steel wool stuffed behind the cat. ive still got it if you need to borrow pm me it might fit.
  • Like 1
https://www.sau.com.au/forums/topic/355437-cops-got-me/#findComment-5691982
Mate thanks alot :) if it gets that far il get intouch hopefully it doesn't
https://www.sau.com.au/forums/topic/355437-cops-got-me/#findComment-5692012
True, at least i know what to do now if i do get done again :)
At the time i got done, i had little money because of job issues and the missus had to help me out to buy all the stock parts, with 2 weeks to get all parts, installed and go for inspection....... I was really up sh*t creek. Makes me sick thinking about it actually.
https://www.sau.com.au/forums/topic/355437-cops-got-me/#findComment-5692561
Tuff break ive had it happened to me a few times in the past and its getting ever more hard to get these cars past without going through the headaches
of finding the standard parts to go back to :/ luckily for me no emissions.i dont think i would of past with a power fc been told once tuned your car will
produce higher amounts of pollution resulting in failed inspection?
https://www.sau.com.au/forums/topic/355437-cops-got-me/#findComment-5702785
i have the following if you need it.
Stock airbox + snorkel.
Stock dump pipe (no stock cat back sadly).
Stock Cat.
Stock SMIC with all hoses / piping needed to fit it.
Can also help fit it all if your not familiar with that kind of stuff.
PM me anytime :)
https://www.sau.com.au/forums/topic/355437-cops-got-me/#findComment-5708880
I have a question, where were you driving when you got defected? I must be out of the loop but I've owned more than 10 skylines in the last 10 years and never been defected once. the closest I came was getting pulled over by highway patrol in a silvia I had just bought. it was heavily modifed, it started life as a CA non turbo auto, but was no SR20, manual, turbo, with trust turbo, stainless mani, nismo 2way LSD, twin plate clutch, 5 stud conversion, full uras kit, coil-overs etc etc. lots of mods. he said mate either get it engineered or take it off the road and make it a race car. he said "my advice is do the second option as it'll never pass rego". he let me off though with just that advice as I had only recently bought it.
https://www.sau.com.au/forums/topic/355437-cops-got-me/#findComment-5709773
Stock Cat.
Mate you are an absolute legend thanks il get the date of my inspection and msg you thanks again
PM me anytime :)
https://www.sau.com.au/forums/topic/355437-cops-got-me/#findComment-5712285
No worries.
Just throw us a PM on here or a txt on 0403 273 338.
i live on the central coast but work in north ryde so weekend is easier but can work something out :)
https://www.sau.com.au/forums/topic/355437-cops-got-me/#findComment-5712676
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
