Hey all
So today whilst driving (with my daughter in the car) at speeds of a MASSIVE 40kph I got pulled over (a common occurrence) after the old pop of the bonnet , click of the camera I now have a EPA referral :-( . He says my exhaust is too loud which I wont argue till I have facts , my front mount needs to be emissions tested and my pod filter which is under a enclosed aluminum housing (his argument is the bottom is not enclosed . Has any one had to have a EPA test for any of these 3 things ? My problem is I don't have any stock parts to change over and I imagine the wouldn't be cheap . I'm going to see what my options are regarding the dealer I bought it from because it "passed" a blue slip fitted with these things , the cop said I can write to the EPA and have them hunt down the dealer ?
https://www.sau.com.au/forums/topic/355437-cops-got-me/
bad luck there,we are all driving our liners with a fair amount of mods.So far in nearly 10 years of having a 33 i have never had pop the bonnet please,i guess being an old girl helps.I hope you get it sorted asap.Genelle. :cheers:
https://www.sau.com.au/forums/topic/355437-cops-got-me/#findComment-5690603
theres a couple of threads relating to people having these problems...its a major pain in the ass..i had a similar thing happen to me...you dont want to go for an emmisions test coz it is pretty hard to pass...you will not pass with a stock exhaust..
.best option (which i ended up having to do in the end) is just just buy/ borrow or steal standard side mount, airbox and exhaust..swap em over, go to the inspection station get it cleared and it will be sweet, its a lot of mucking around considering 99% of people will just swap it back anyway
good luck
https://www.sau.com.au/forums/topic/355437-cops-got-me/#findComment-5690645
i got EPA for noise, your car will NEED to be at or under 90 DB at 4,700 RPM. i went to the bloke at granville, he was a knob and failed me first time due the the silencer in my cannon not being fully welded and "part" of the exhaust. i came in at 90 db.
Metal flange piece and steel wool stuffed behind the cat. ive still got it if you need to borrow pm me it might fit.
  • Like 1
https://www.sau.com.au/forums/topic/355437-cops-got-me/#findComment-5691982
Mate thanks alot :) if it gets that far il get intouch hopefully it doesn't
https://www.sau.com.au/forums/topic/355437-cops-got-me/#findComment-5692012
True, at least i know what to do now if i do get done again :)
At the time i got done, i had little money because of job issues and the missus had to help me out to buy all the stock parts, with 2 weeks to get all parts, installed and go for inspection....... I was really up sh*t creek. Makes me sick thinking about it actually.
https://www.sau.com.au/forums/topic/355437-cops-got-me/#findComment-5692561
Tuff break ive had it happened to me a few times in the past and its getting ever more hard to get these cars past without going through the headaches
of finding the standard parts to go back to :/ luckily for me no emissions.i dont think i would of past with a power fc been told once tuned your car will
produce higher amounts of pollution resulting in failed inspection?
https://www.sau.com.au/forums/topic/355437-cops-got-me/#findComment-5702785
i have the following if you need it.
Stock airbox + snorkel.
Stock dump pipe (no stock cat back sadly).
Stock Cat.
Stock SMIC with all hoses / piping needed to fit it.
Can also help fit it all if your not familiar with that kind of stuff.
PM me anytime :)
https://www.sau.com.au/forums/topic/355437-cops-got-me/#findComment-5708880
I have a question, where were you driving when you got defected? I must be out of the loop but I've owned more than 10 skylines in the last 10 years and never been defected once. the closest I came was getting pulled over by highway patrol in a silvia I had just bought. it was heavily modifed, it started life as a CA non turbo auto, but was no SR20, manual, turbo, with trust turbo, stainless mani, nismo 2way LSD, twin plate clutch, 5 stud conversion, full uras kit, coil-overs etc etc. lots of mods. he said mate either get it engineered or take it off the road and make it a race car. he said "my advice is do the second option as it'll never pass rego". he let me off though with just that advice as I had only recently bought it.
https://www.sau.com.au/forums/topic/355437-cops-got-me/#findComment-5709773
Stock Cat.
Mate you are an absolute legend thanks il get the date of my inspection and msg you thanks again
PM me anytime :)
https://www.sau.com.au/forums/topic/355437-cops-got-me/#findComment-5712285
No worries.
Just throw us a PM on here or a txt on 0403 273 338.
i live on the central coast but work in north ryde so weekend is easier but can work something out :)
https://www.sau.com.au/forums/topic/355437-cops-got-me/#findComment-5712676
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi ๐Ÿ™‹โ€โ™‚๏ธ. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? ๐Ÿ˜ƒ  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this ๐Ÿ™
    • Hi, Marek here ๐Ÿ™‹โ€โ™‚๏ธ. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
ร—
ร—
