Wtb Skyline
2quickr32
 Share
Hi mate,
Seems like you are new - welcome aboard. Have a look in the for sale section - there are heaps of cars there. I'd also suggest having a look around carsales. There is a thread in the FAQ section of the forum about what to look for in a line too.
In your budget there would be a couple of models that suit - the R32 and the R33. Did you want a turbo or not turbo?
R34 auto gtt's are Selling for under 10, they are all "tiptronic" and would be the best bet being newer and best package, especially with the auto
....... And it's not a 33
....... or God forbid, a 32
There was a really clean r34 4 door auto selling in canberra for, like, 8.5k, it was a dark metallic silver and looked really clean. It was posted in the Canberra section recently, probably sold now though.
That owner I believe was in a rush due to moving overseas or something, so yes hopefully it might still be there for you, though don't take that as the "going price" - it's a rare occasion
I guess was still a good idea asking around locally if anyone had one they were in a hurry to get rid of. Look at the R34's on car sales, but check what is on carsales and all classifieds, follow the checklists in the faq's closely. Get the car checked over by a mech (general + compression)and see that will pass rego. Take it for a test drive and best wishes!
Are you serious '2quick'?
Your opening question "I wanna buy a Skyline" being one of your first posts makes me suss! but then again I trust no-one...lol
If your serious then check out the forums and all your questions will be answered.
Happy to help if your legit..
The folks on their way to lawn bowls or golf on Sunday mornings seem to be enjoying the drive in their Camry's, so much so that they drive really slow to savor the moment.
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
