HI ALL,,,
I have a r33 with RB25, Power Fc with hand controller,
Up untill yesterdy all was fine, not had a prob before with it.. water temp would sit 78 - 80 once fully warned up after (about 5 minutes) and might creep up to 83 after few hours driving,Fine right? been like that for years
Right,
My cars been sitting in the pannelbeaters the last couple months, (front bumper damage and minor side pannel damage) the radiator didnt get touched atall in accident baring in mind, but they had to remove the rad to do work, when i went to the place yesterday car was running, they said it had been running a couple of minutes and i looked at Fc hand controller and Water said 60.... i then revesed straight out of the unit (20ft) got outta car. talked for honestly no more than two minutes, Got back in car and hand controller was reading 114c!! pannelbeater says nah that cant be right because the stock temp gauge is only reading just above halfway mark?
Please all! Am gratefull of all advice!!
CHEERS AGAIN
https://www.sau.com.au/forums/topic/355488-r33-gtst-extrem-over-heating/
Let it cool Nd check the coolant level. If its ok leave the cap off open the air bleeder screw on the inlet manifold till coolant comes out then refit the bleeder screw and start the car, let it idle till it warms up with cap off and heater on.
This should remove any air that is still trapped in the cooling system.
If it still overheats get a new thermostat
in my experience, the stock temp gauge reaches half-way around 60-65C and will stay there till around 110C before rising - so it could be easily right.
+1 on bleeding the coolant system too.
You may have air in the sysyem, When the car is cool remove the radiator cap and start the car, let the car idle for a while(might take 5-10 minites), giving it a few revs here and there, watch your temp gauge, and add coolant as needed, also ensure you have some coolant in the overflow for when the car cools down so it doesnt suck air back in.
Might fix it.
Mark
+1
Basically from my experience the stock temperature gauge should always be reading just under 1/2 way for a normal operating engine at normal temperature.
If it gets to 1/2 mark then thats enough to throw a caution, anything over 1/2 means there are potential over heating issues with the engine.
I had my gauge read just over 1/2 way & when I pulled over the coolant was boiling in the reserver tank, even though according to the stock gauge it's no where near the H mark, had it checked & it turned out to be a worn Rad cap & thermostat.
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
