Well after having a chat to rta tech team , inspection agency and department or fair trading it seems that the yard I bought my skyline from are in very big trouble . At the time my car was blue slipped the dealer failed to provide the blue slip station with a certificate of engineering meaning it was blue slipped illegally and they also failed to provide me with a certificate of engineering. So now Im going to hit them for the full cost of replacement stock parts and labour to fit them aswel as EPA fee's ... Hopefully it stays on this path and all goes to plan
https://www.sau.com.au/forums/topic/355497-a-big-oops/
Thats heaps good,bet they get reamed hard. :teehee: Please pm where you bourght it from.
https://www.sau.com.au/forums/topic/355497-a-big-oops/#findComment-5691454
Mate did you have a read of the vs1 06 before posting ? One of the things that it clearly states isSTANDARD emissions components must be retained and operate correctly I.e exhaust system , catalytic converter .... Considering I have a hi flow cat and full 3 inch exhaust I'd say it's in breech of this wouldnt you ?
https://www.sau.com.au/forums/topic/355497-a-big-oops/#findComment-5691850
I'm keeping a close eye on this thread,when we got our 33 from a dealer on parra rd nearly 10 years back she was a fresh import from jap,stock every thing. :blink: I'm on your side mate.I realy hope the dealer has to sort this for you.
https://www.sau.com.au/forums/topic/355497-a-big-oops/#findComment-5691870
Actually yes, many times over, and with an engineer before.
And I quote:
Normal engine reconditioning within manufacturers limits is permitted;
Modifications must not affect compliance with any emission or noise related ADRs;
All emission control equipment must be retained and functional;
It does NOT state standard.
Before being able to make them pay for shit, you will have to prove it doesn't meet these standards when these items are new and in a functional condition.
And I'd say they're legal as long as they're put on correctly, I ran a high flow cat, and a 3" exhaust, it met both gas and noise emmisions, and was therefore owner certifiable.
https://www.sau.com.au/forums/topic/355497-a-big-oops/#findComment-5691906
I think you better read it again mate :-) it's the number one example of minor modifications
You're reading an example.
Try reading under the part where it actually explains what you can / can't do and what you need to do. ;)
The RTA can not legally force you to retain "STOCK" parts as depicted from Nissan, you have to be able to go outside and use replacement parts, you're also allowed to modify your car. If you want, go dig up the actual ADRs and Emmision regulations. You will find you really don't have much of a leg to stand on.
So long as when that cat is new, it passes emmisions and the same with the exhaust, you can't go them for the exhaust, and the POD is in an enclosed box. This is what the ADRs dictate.
Before you can get any damages paid to you, you will need to PROVE that the exhaust and cat (When new) don't pass emmisions.
Remember, cat convertors are a consumable item, and are meant to be changed roughly every 60 000KM.
https://www.sau.com.au/forums/topic/355497-a-big-oops/#findComment-5691951
Well at the end of the day I can't lose ... It passes all EPA tests and nothing happens or it's found to be illegal and it's replaced . But this does still not change the fact that regardless of the modification an engineers certificate must be supplied when a blue slip is issued ( how is the blue slip guy to know whats passed engineer and what didn't with out it ) without the certificate the blue slip was issued illegally ( that's according the Australian inspections agency) and department of fair trading states it's also against the law to sell me a car without the certificate
https://www.sau.com.au/forums/topic/355497-a-big-oops/#findComment-5691994
can see where you are coming from mate, hopefully you breeze through your inspection and it wont be a problem..but the problem you have is that you have to be able to prove that the car passed the blue slip with illegal aftermarket parts..
and you have to prove that those parts were never able to pass emissions. because if those parts ever could pass emmisions but no longer will then i believe it is the current owner of the cars responsibility to replace them..i may well be wrong though, im only going off what i was told by the rta, police and deccw when i got in trouble previously...good luck with it mate.
https://www.sau.com.au/forums/topic/355497-a-big-oops/#findComment-5692021
Il make some calls tomorrow and follow this up because what your telling me is different to what rta tech is telling me ... They have verified that there is modifications on my car that have been and were required to be engineering but they can't specify exactly what the parts were without the certificicate being that these are pretty much the only aftermarket mods on my car I'm guessing they are on the certificate
https://www.sau.com.au/forums/topic/355497-a-big-oops/#findComment-5692022
Do a cool little test, call the RTA tech, get the answer, hang up, call them back, ask them the same thing.
Do this 5 times... You'll find you have 5 different answers.
If there was an engineers cert listed it should have the number on the rego papers. I know mine used to on the R33, and on the Supra.
If they're not listed, then the RTA won't have any clue of an engineers cert.
If it does already have one listed, then ask the RTA for it, as it's still valid.
https://www.sau.com.au/forums/topic/355497-a-big-oops/#findComment-5692134
On the bottom of my rego paper it says "modified as per report as per report number - xxxxx "
https://www.sau.com.au/forums/topic/355497-a-big-oops/#findComment-5692172
Then he won't need the cert.
You need to get a copy of the engineering certificate from the RTA, get the defect cleared, and carry the cert with you in the car.
https://www.sau.com.au/forums/topic/355497-a-big-oops/#findComment-5692334
When I asked the rta they told me to obtain it from the dealer il call again tomorrow and see of they can issue me a replacement and there is no defect yet I have a letter of referral to the EPA
https://www.sau.com.au/forums/topic/355497-a-big-oops/#findComment-5692432
It would have been done most likely before the dealer got it. The RTA are meant to have it on file.
https://www.sau.com.au/forums/topic/355497-a-big-oops/#findComment-5692524
that would probably be for compliance mods? If so id imagine most imports would have it. My RX7 has that too but has nothing that needs engineering and i doubt it ever has.
https://www.sau.com.au/forums/topic/355497-a-big-oops/#findComment-5692558
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
