Guys,
what i have for sale is a cat back Fujitsubo exhaust
its a 3inch in to twin 2.5inch piping rated for 400kw and was holding my power at 360kw
its a very nice not to loud exhaust very cop friendly but still a nice deep sounding exhaust
i have a pic of the system but its not mine as i haven't taken it off yet
ill leave it on for another week before i put my other exhaust on so it gives you a chance to come hear it if you like.
reason for sale is my car is now only used for track
so there's no point of having 2 exhaust sitting around
i'm after $450 ono
located in melb
best contact by pm as my phone is playing up at the moment
Dean
Hey guys, i bought this off 'Deanc' last month but since then sold the car.
Never had a chance to put it on so its still in the garage.
Chasing the same price as above.
Still in good condition. Can send pics on request but looks like the picture attached.
$450ono
Call Merv on XXXXXXXX, I dont go on SAU anymore due to not having a skyline.
-Merv
Edited by Nightcrawler
https://www.sau.com.au/forums/topic/355535-r33-catback-fujitsubo-exhaust/
Quieter than most and possibly one of THE BEST off the shelf exhaust systems to ever come out for the R33. A stupidly good price if it is in good condition.
Edited by simpletool
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
