I'm not far off making the leap into E85 territory. One deciding factor in it for me, is compatability with Caltex E85. I can't be assed travelling to the few independant servos that carry E85, they are just too far away from me. Once in a while, maybe, but not every tank. And if I run E85, I want to run it somewhat permanently.
Now, not so long ago, there were several discussions and concerns expressed within E85 related topics here on SAU - questions about whether the Caltex brew would be safe to use, given Caltex did not want to guarantee the percentage of ethanol in every tank (which was to change between 70% and 85% anyway, depending on summer and winter seasons). This is a non-issue for new cars designed to run on E85, as (from what I'm told) they used sensors to detect ethanol content and adjust fuel maps accordingly (something to that effect). So the consensus at the time of these discussions, was that unless you A. had an ECU with 3D fuel maps, B. tuned your car to run the mix straight after filling up, or C. had about 10 different tunes ready to load after filling up, you should stay away from the Caltex E85.
What are the latest thoughts on this? I ask because I was talking to a Stagea owner the other day, who claimed to use tank after tank of Caltex E85 with no issues at all. He also had a wideband O2 sensor to keep an eye on things.
  • Nope 1
https://www.sau.com.au/forums/topic/355537-caltex-e85-anyone-using/
I think Scotty NM35 mentioned the change in AFR's on his wideband between the 70% blend and 85% blend being f**k all, as well as the fact that if you've tuned into the sweet spot but not beyond, you won't REALLY have to worry about any damage being done.
e70 on e85 map = running slightly rich which will compensate (with some minor negative things like eventual fouling of plugs perhaps? certainly no detonation)
e85 on e70 map = running slightly lean, but theoretically shouldn't detonate due to increased ethanol content. Will run a bit shitty though, should still be relatively safe.
You're right though, it's not a gamble you can make without a wideband sensor and ability to swap maps on the spot once you see that you're running the "other" stuff. You'd also want to either have your maps somewhat conservative to compensate for a mix in e70 and e85, which could mean you'll have anything in between, or 3 maps - 70, 77.5, and 85% ethanol
  • Like 1
Im running caltex e85 no problems, got a 40kw up top and yeah in regards to the variance in ethanol content if you get it tuned to leave some margin for when the mixtures change you wont have a problem. I got it done at status and trent was confident theres no problem if the tune accounts for the change.
  • Like 1
i have used it and i know someone else from down (or up as the case may be) here that uses it. i havent noticed much change. worst case you get it tuned for E85 and run it on that tune all year round as some have commented their switch from E70-E85 made about 1 AFR difference (eg cruise of 15:1 became 16:1) where as if you are tuned on E85 and it changes to E70 it only gets richer.
  • Like 1
well basically yeah buy a WB02 to keep an eye on things, but the consensus is an E85 tune done with a little bit of wiggle room in the AFR and not 'on the edge' timing wise is fine to use with the varying caltex brew. best to talk to your tuner though and find out what he's comfortable with but personally I wouldn't be too turned off. just keep an eye on the WB02 after fill-ups and you should be fine.
  • Like 1
The conversation I had with the caltex dealer implied that whilst the ethanol content would vary between summer and winter the ron rating would not.
I am going to use wide band just to be on the safe side and some logging over a period of time should make or break what they had to say.
  • Like 2
  • Nope 5
LOL I was going to say, what's wrong with Noel's post?
Cheers for the advice, it's good to know. Think I'll get a WB sensor and conservative tune, maybe 2 switchable tunes (E70/E85) if I can afford it.
E85 here I come :D
  • Nope 1
So you don't have a wideband or anything to monitor AFRs? I suppose if Trent has recommended that then you should be ok. Having to switch maps and buy a wideband etc etc is making converting to e85 just a bit too inconvenient for me atm.
Forgive my ignorance, but if the RON rating stays the same can AFRs still be affected? Would be good to get some concrete info from Caltex re: their mixtures
yer the AFRs will be directly affected by the % of ethanol in the fuel, which if constantly mixxed with the same type of ulp will affect octane rating aswell (albeit not enough to be dangerous), the only way they could lower ethanol content without affecting octane rating would be to mix it with a higher octane ulp
has anyone noted how much an octane booster can actually affect AFRs, as I was thinking if I run E85 as my only tune but then cant find E85 on a cruise somewhere that I could possibly use 98 and some octane booster...
would that work or am I asking for trouble... otherwise I'll be limited to 250ks before I need to find E85 or pay the price get datalogit to change maps over to 98 tune...
I see. So is monitoring AFRs and changing maps the only way this caltex fuel is going to work? Tuning conservatively and just absorbing the difference doesn't seem optimal
you can do it on the hand controller???
how? I didnt know you could switch maps through it....
you cant change maps, but you can add/remove fuel etc, to make it safer.... only a bandaid solution to limp home really
At the worst it will involve some minor corrections to your tune once a year. either that or run 2 maps.
As I am to understand it the change in ethanol content will not be random. Merely a summer to winter adjustment.
That will not be difficult to work around.
  • Like 1
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
