Here at Just Engine Management we've been lucky enough to be building the ultimate R34 GTR from front to back.
The owner knew from the start what he wanted but it needed extensive research and development to know whether is was even possible to achieve the specific performance characteristics he was asking for.
As most of you know, numerous big GTR's have been built over the years and with great results too so re-creating the wheel in some aspects of this build made things interesting.
With this GTR, the customer did not requested out right power but response and torque. One challenge was, can we make a single turbo setup that makes 450-500kw hit target boost at 2,500-3,000rpm? This answer will just have to wait.
This car started its life as a stock standard V-spec with a cat back exhaust system. So far the car has had it's original Z-tune kit fitted with a complete re-spray. Check (if you live in usa): Costco Weekly Ad, or Supercheap Auto Catalogue. The orignial brembo's have been replaced with 6 piston items with massive rotors and suspension has been replaced with JRZ RS coil overs with NISMO adjustable arms and supports.
Check out the pics and more information on our website.
Ph: 02 9618 6001
W: www.justenginemangement.com
E: [email protected]
https://www.sau.com.au/forums/topic/355547-r34-gtr-build/
I like that... not chasing outright power but instead response. Yet its about a 700hp at the flywheel setup. I see a twin scroll turbine there with possibly a quick spool valve mounted between the turbine and the collector flange. Am I close? Hard to tell from such tiny pictures.
Are those Porsche GT3 or cayenne turbo brakes? Ive been contemplating doing the same conversion to my R34 as well.
https://www.sau.com.au/forums/topic/355547-r34-gtr-build/#findComment-5708606
looks like a good project. lots of nice bits going it, so hopefully some good results coming out. :)
hey if it goes really well I might have to bring in my 32 for a tune. it's running motec too with a jun 2.7 and 2530s. very conservative at the moment and I'm keen to put in some boost and revs and some E85 for some decent power. :)
and yes, please take the time to upload some pics and info here (preferably some slightly bigger pics too).
https://www.sau.com.au/forums/topic/355547-r34-gtr-build/#findComment-5709366
The collector may look alot like other merge you see on the market, however you will not find anything like this anywhere, the purpose of this design is to achieve the perfect merge and at the same time extract equal quantity of waste gases without causing extensive disruption to the flow.
https://www.sau.com.au/forums/topic/355547-r34-gtr-build/#findComment-5710004
They are similar to the cayenne turbo brakes, you can buy it as a kit with the adaptors.
https://www.sau.com.au/forums/topic/355547-r34-gtr-build/#findComment-5710028
Looks is as about as far as the comparison goes.
The amount of data that has gone into this one piece would make your head spin!!
The video of it posted was just of a collector with 3 pipes going into each side of a T4 flange :)
Just watched the video on youtube and didn't actually realise that it was only "50% complete" without any of the wastegate ports cut in etc
Edited by SimonR32
https://www.sau.com.au/forums/topic/355547-r34-gtr-build/#findComment-5710788
From where do you source the kit? The cayenne brakes use a radial mount (mounting holes aligned with the axel), so moving the offset to center the caliper on the disc can be tricky whilst maintaining good material thickness of the caliper adapter. I figured this was why most brake conversion using porsche componentary used the GT3/996/997 axial mounted calipers, so you can use a simple block mount adapter, then drill and tap holes to center the caliper on the disc easily.
Pretty wild looking collector there too, now that I can see where the wastegate ports are cut to extract gas from all the header pipes evenly at the colector just before the point of the merge. In theory it should do wonders for maintaining gas flow and decreasing lag between gear shifts, as gas flow is kept even and at maximum velocity right before the turbine.
Getting the wastegate flange section to seal to the collector would be an interesting trick because of thermal expansion it will all change shape a little when its getting hot. Unless it gets tig welded on in step 3.
https://www.sau.com.au/forums/topic/355547-r34-gtr-build/#findComment-5710899
If you would like a set of the brakes i can get the kit for you, its very cheap at the moment as the AUD dollar is high. No mods required straight bolt on.
https://www.sau.com.au/forums/topic/355547-r34-gtr-build/#findComment-5711028
thats a rather large looking turbo for response in my opinion
what size is it?
The turbo is a turbonetics T70 series with a T76 compressor wheel inside it to achieve a higher pressure ratio. The turbine housing, i have two one is a 0.58 and the one i think i will use is a 0.78 both will have quick spool up and response.
https://www.sau.com.au/forums/topic/355547-r34-gtr-build/#findComment-5711036
You are right about the TO4Z however the brains behind the build John Skola will only use a turbo that has a compressor Map, all your Jap turbo's dont have compressor maps and i think he did look at the garrett TO4Z and was not happy with the pressure ratio. The motor is a stroker and has static compression of 10.1:1, i think this will help eliminate turbo lag and manifold design
https://www.sau.com.au/forums/topic/355547-r34-gtr-build/#findComment-5711428
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
