Here are some more pic of the manifold. Its coming along well just needs some final welds, 4 years of development its looking good.
Now the next stage making the dump pipe out of two flat sheet of stainless welded on its edge, and then blow it up using hydraulic fluid. Interesting way of making it to achieve the correct tamper coming out of the turbo housing and the correct dump angle, all in one piece of pipe.
It looks great, I hope that 4 years of development pays off with real gains rather than just taking 4 years to make a shiny manifold. Did you configure your pipe placement at the merge according to the firing order of the RB26 or did you just first 3 pipe before the divider and the back 3 after the divider?
The firing order for a RB26 is 153624, therefore the first 3 pipes are correct for one side of the divider hence the last 3 pipe are correct for other side of the divider. If you think the placement should be different please let me know.
Also I have not mentioned, the manifold collector is made from billet 321 stainless and all manifold pipes are 321 stainless.
Dam, Gandalf would want to be pretty dam sure of the quality of his welds! What pressure was used to inflate the pipe? I'd be terrified to stand near that when its inflated let along bang it with a hammer at the same time. Ive heard too many horror stories of hydraulic fluid at high pressure cutting through skin like a razor, or worse filling a cavity in your body with fluid.
The end result is very impressive though. Gandalf is definately a wizard.
His Name is JOHN SKOLA no man like him his the wizard brains behind many motorsport stories, however no one really knows him as he keeps to himself.
The pressure used was not alot i know i have had one blow up lucky i had it covered up. Once the pipe is finished ill post the final product, it is going to look amazing and at the same time delivery its purpose.
I noticed John being a little camera shy in one of your earlier videos.
Its amazing watching guys like this work. Reminds me of an old bloke that used to work for an engineering firm that I work for. He trained the majority of the boilermakers in cairns about 20 years ago. He too is a boiler maker by trade, but also a metallurgist.
Guys like these have an understanding of metal that current generation boilermakers will never attain. When people say it cant be done, they design and build the tools to do it, and then prove everyone wrong without any display of ego. True craftsman.
I completely understand , I have known John for like 16 years now and all this time i never asked him to do work for me as i always got work done for others. John has said this is his last project involved with car's. I am the lucky guy to have something no one has ever done, however I am willing to share all the secrets as i dont see the point of hiding anything. So let everyone know what ever info people need i am more then happy to let them know in full detial to what i know and what i understand.
that merge collector is something else hey.. im seriously considering throwing my manifold in the bin now to make something like that haha..
awesome metal work.. he definitely isnt your average boiler maker.
Well even if you copy 50% it will be better then anything on the market. if you need some more detailed pic do let me know.
Are those Porsche GT3 or cayenne turbo brakes? Ive been contemplating doing the same conversion to my R34 as well.
Porsche cayenne brakes have no place on a performance car. Having ordered a "kit" from someone that used cayenne calipers. When it arrived, I realized I had screwed up. Not even getting into the adapter, rotor, or brake line issues just the caliper alone was enough to scare me off. The thing probably weighed 15-20lbs each with pads installed and when I checked the part numbers you could buy them from porsche for 500$. No was this has the quiality of material or consruction for a high performance car.
Back on topic. How much would a manifold like this cost?
When i bought the brembo kit, it was not listed as cayenne brakes it was listed for r34 Gtr, I had no issues in installing the kit myself and im no mechanic so im not sure what kit you have bought. If you need some close up details of the caliper i can take some close up pics.
The manifold cost is over $10,000 just the material to construct cost me about $3500 as its all 321 stainless purchased from USA.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
