Here are some photos of Bobby's RB26 head with porting and modifitcations.
Bob would you like to explain what's been done here?
Thanks
JEM
Not sure if anyone has noticed the exhaust port, the bump has not been cut out, I know everyone out there has cut this out but john has not cut it out?? let see who can tell me why??
I honestly have no idea, but ill take a stab at it causes turbulence which helps bind the pulse together, so ultimately it will hit the turbine wheel more effectively.
Well the correct answer is, there is a water gallery right behind it if you cut it out your wall thinkness is reduced to <1.5mm think, this was found when we got a rb26 head and John started to cut sections out of it, he has checked the whole head where he could gain more performance from it and at the same time keep away from any thining walls.
You can see it in the below pic
The motec setup see below pics
M800
E888
Ignition Expander
Shift light
M800 - Will run all the factory sensors plus run twin Nismo AFM no Map for tunning. Control diff, trans, and front diff cooling pumps, Dual lambda, custom wiring for 12 injectors all running sequential ,speed controlled Fuel Pump, fuel pressure sensor, fuel temp sensor. E85 analyser for ethanol content (zeitronix sensor), water methanol injection
E888- Will be used for 8 k type thermocouples installed in the manifold runner and exhaust, 4 pressure sensor exit of compressor housing to the plenum. 4 air temp sensors exit of compressor housing to plenum. Compressor wheel RPM,Diff temp,trans temp.
Ignition Expander - this will control the sequential IGN as the output on the M800 are used for the other set of injectors.
Shift light - This has three different colour on each light that can be configured for warnings and shift lights
Motec would have to be one of the best ECU system for a car as you can make it do what ever you want it to. Yes it is expensive however if you want to do it properly then this is the product.
I was very happy that Just Engine Management is a dealer for Motec and Adam at Jem advised what the car needed, i guess this is just the beginning as i am sure i need alot more Motec equipment to complete the car.
  • Like 1
The wastegate collector has been slow as John has been busy making the die.
See below Vid
He is making this die so he can beat the pipe into this shape for each of the two wastegates entering the dump to form a venturi. I know this is getting out of control however i guess, him making these things is all a challenge to him also.
  • Like 1
bobby, with motec it doest stop haha by the time i finished with my car it was well into the 30s!! wiring, slm, dash, 1 million sensors it gets up there fairly quickly!!
Yes i know i was just told today i have to use some special wire "tefzel" for all the sensors with raychem.
Also i dont see anyother ECU out there that can do what i need it to do.
Awesome build dude keep us posted !
I know of a good ECU "Apexi power fc" does the job for me lol
loving the thread mate. great stuff. I would love to come and talk with john about his ideas one day. he is a fantastic craftsman that's for sure.
I run a motec in my 32 too, not nearly as comprehensive as yours though! but it does run very nicely.
I'll echo some previous thoughts on using an EFR turbo. I have a lot to do with both borg warner and full race at the moment and would be happy to make an introduction? I'm sure they could supply the info john needs to make an informed decision about their product. pm me if interested.
    • Yeah, thumbsup from me. The distant shot of the bay just looks same-same as before.
    • Dad had a court case drag out with them from 1998 to 2004. He was in a not at fault accident, NRMA were the ones who covered the other person. They tried to blame his neck injuries on the fact he'd had an injury in 1981 on his extreme lower back where he slipped a single disc right near the bottom. Had been all cleared from that injury for years. This accident destroyed his shoulder, and f**ked a heap of discs in his neck, and he still has major problems with it to this day. Sarah's sister while on her L plates had a small Suzuki Alto, she had stopped to give way to an ambulance, and someone changed lanes behind her because there lane was also slowing, and rear ended her at 80km/h. (She had been stopped for a few seconds already too!). Car was completely f**kED. NRMA sent the vehicle around to 3 different workshops as they kept claiming "We believe it can be repaired, and not written off, we just need to find the correct workshop". It took 3 months, and a lot of arguing before they'd concede and wrote it and paid out. About two years later her sister had a Lancer, someone pulled out of a stop sign without stopping (in an 80 zone). Her sister swerved, hit the front of the other persons car (Instead of dead t-boning the drivers door), which ramped her Lancer, and made it roll multiple times down the road. It hit every panel on the way through. Her sister had slid her self out of the car, and remembers the ambos walking to the accident (They'd been sitting at a set of lights just down the road and witnessed it) and they were saying "Well, this ones going to be a fatality, no way you can walk away from that". Well, she did. And then NRMA sent two assessors out to look at the car, both of which wrote it off. They tried to send another assessor out, except a HUGE uproar was raised, and they FINALLY paid it out. That was on a car, that had damage to EVERY panel, you could see from 100m away the whole car was also twisted, roof bowed etc. Nah, we'll try get out of needing to payout on a $10,000 car... Her sister ended up with major shoulder reconstructive surgery being required, and was permanently limited in her ability to do her job as a nurse after that, as she can't (And was told before surgery too this would be guaranteed to happen) regain full strength in that shoulder. However, there was no choice to not have it, as she could barely use her arm, which was her dominant one, and was in near constant major pain. (And she's the type of person that would try and walk off a broken leg!) NRMA did the biggest run around on the personal injury side too for about 18 months, even to the point of trying to put 100% blame of the accident on Sarah's sister, even though the other driver admitted she didn't look, and didn't stop, and was charged by the police. Sarah used to have a Barina insured with them. It was a policy setup, paid all 12 months in advance. At the end of the 12 months, Sarah was living with me, I reviewed the renewal, it clearly stated "If you do nothing, your policy will cease on XYZ date". We did nothing, as we moved her insurance in with all of mine and I was with Shannons. We find out 10 months later, NRMA decided, because he DAD had a car insurance policy at the same address as what Sarah's mailing address was (Garaged address had been changed), that they'd put Sarah's (What should have been non existent policy) onto her Dad's month to month charges on his credit card. We had to jump through hoops, to get a refund. They didn't care that we actually found the letter that said "If you do nothing, your policy will cease" they made us prove we had NON COMPULSORY insurance else where before they'd issue the refund, and after they agreed to the refund, it still took another 6 weeks and 3 more phone calls for them to actually process it. They also had two insurance claims from storm damage, and they were an absolute cluster to get resolved as well (one vehicle, one house). Some how, up until about 3 years ago, her parents were still loyal to NRMA too, and we were like "How the hell are you so loyal to staying with them, when other places are so much cheaper, and they've f**ked you over every time you've ever had to make a claim?"
    • I got the four AN10 fitting welded up to the cam covers and started up making the head to sump breather/drain lines. The front passenger side cover I used a 45 up top and a 90 at the bottom into the stock VCT head drain spot (3/4" BPST to AN10 adapter) thats unused on the RB25DET NEO with some speedflow flame shield to protect it from the manifolds heat.   back passenger side was a 90 up top with some flame shield and 45 at the sump end. The rear drivers is 45 at both ends   the front drivers fitting is capped off for now but ready to go if i want to try moving the breathers around. I was told by the fabricator to leave all the welds raw for now to make sure there are no pin hole leaks. A lot of cleaning up, re bundling looms and degreasing to go as well as final assembly on the cam cover baffles. The first real test will be 28th March at a Circuit event. added complexity and more spots for leaks but overall looks relatively neat imo
    • Yeah i think the dash needs to come out. To get the loom or maybe just climate control and radio cluster. My mirrors are done i think the motors don’t work so well after flood haha i need the ac fan, you said you wanted to keep it for your 31 and interior loom not including boot. The wiper motor. I’m not sure how good the window surrounds are on the exterior on the pintara.  I will message you to get your bank details shortly
    • Just another barrier put up to stop cars being modified. When we're all driving Chinese sewing machines, you won't want to modify it anyway, and you'll likely already have slashed your wrists and be locked up in a padded room for your own protection.
