...:woot: ...
i am really looking forward to see how this goes as i have been thinking about doing something similar for awhile now but i don't think what i build would look as pretty. :)
Well i think you should give it ago, and if you need any info i will be more then happy to provide you the info.
thanks
it's nice to know that there are still nice people out there that will help there fellow car guys out. :)
Bobby
I have only just come across this thread and gone from beginning to end in a session.
All I can say is this is truely an amazing endeavour, something I can only aspire to.
Can't wait to see the final output.
Thankyou for sharing so openly.
Regards and respect.
Bobby
Thank you for your comments
Needs more updates with pictures!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Yes i know its been awhile, John is doing the final stages on the venturi dump will have pics this week sometime. Also he is in the process of desigining the plunger infront of the turbo!!!! more details to come soon.
The motor builder is looking at drilling the head to relief air locks. Will have full detailed pics on how we will fix this problem.
hahah i love that quote bobby!! some time this year!! heres to hoping u get an early xmas present!! good luck !
Thats at least a realistic goal.
The last car build I started took 3 years to finish! Way too long, as I got so frustrated with how long things were taking I had time to buy an R34 and design an engine upgrade for it!
This is deadset one amazing build... I'm still dumbfounded by the perfection of the turbo manifold. As a Fabricator myself, I learnt early that I would never know as much as the older guys. It's a shame that real fabrication is a dying art... Metalurgists are a dime a dozen. I would trade in everything to have a fraction of John's skills and knowledge... But enough of the tradesman envy.
I can't wait to hear this thing start up once it's complete. You better be posting a video, haha. Money is nothing when it comes to experimention and perfection, and by the looks of it you have succeeded. Keep up the great work! I'll be making sure my eyes are glued on this build.
Hi Robert,
Thank you for your comments.
Yes john has the skills, just remember its never to late to excell in fabrication.
Yes you will have full data once the car is up and going ill be posting vids and even data files just to show how its all going to work.
Cheers
Bobby
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
