What stage pump are you going to be using? On our race car we run a 4 stage pump which scavenges two from the sump pan and then one from the back of the head. We are still using internal draining, though really the ideal would be to weld up all the oil returns and just let that one scavenge do the returning as that would avoid windage induced from oil draining right into the cranks vacuum trail. Has John considered doing something like that already?
Loving this build mate. Keep it up!
Interested in answer to this...
Here is a detailed Vid on how the merge of the wastegate pipe will be down. You need to listen to it with full volume and listen to what John has to say.
Always wondered about the advantages of something like that, following the direction of the turbine wheel/exhaust gas rotation.
The further this build goes the more impressed I am with the thought going into it.
Inducing swirl and/or taking advantage of it is very common in fluid dynamics and effective. Clever.
I am running a 4 stage pump, and yes the ideal way would be to weld the oil drains up , and we did not weld it however we have used bungs for all exept the ones on each ends of the head.
Ok,
The latest is the merge is getting cut up to form the shape that John had said on the Vid above i should be able to get some more pics on it tomorrow.
The next step is to install all the Motec system i have done some work in installing it, will get some pics up tomorrow. The other thing i am installing is the zeitronix E85 sensor to determine the concentration of Ethanol.
I should also get some pic of the bottom end as this has been completed.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
