Here are some photos of Bobby's RB26 head with porting and modifitcations.
Bob would you like to explain what's been done here?
Thanks
JEM
Not sure if anyone has noticed the exhaust port, the bump has not been cut out, I know everyone out there has cut this out but john has not cut it out?? let see who can tell me why??
I honestly have no idea, but ill take a stab at it causes turbulence which helps bind the pulse together, so ultimately it will hit the turbine wheel more effectively.
Well the correct answer is, there is a water gallery right behind it if you cut it out your wall thinkness is reduced to <1.5mm think, this was found when we got a rb26 head and John started to cut sections out of it, he has checked the whole head where he could gain more performance from it and at the same time keep away from any thining walls.
You can see it in the below pic
The motec setup see below pics
M800
E888
Ignition Expander
Shift light
M800 - Will run all the factory sensors plus run twin Nismo AFM no Map for tunning. Control diff, trans, and front diff cooling pumps, Dual lambda, custom wiring for 12 injectors all running sequential ,speed controlled Fuel Pump, fuel pressure sensor, fuel temp sensor. E85 analyser for ethanol content (zeitronix sensor), water methanol injection
E888- Will be used for 8 k type thermocouples installed in the manifold runner and exhaust, 4 pressure sensor exit of compressor housing to the plenum. 4 air temp sensors exit of compressor housing to plenum. Compressor wheel RPM,Diff temp,trans temp.
Ignition Expander - this will control the sequential IGN as the output on the M800 are used for the other set of injectors.
Shift light - This has three different colour on each light that can be configured for warnings and shift lights
Motec would have to be one of the best ECU system for a car as you can make it do what ever you want it to. Yes it is expensive however if you want to do it properly then this is the product.
I was very happy that Just Engine Management is a dealer for Motec and Adam at Jem advised what the car needed, i guess this is just the beginning as i am sure i need alot more Motec equipment to complete the car.
  • Like 1
The wastegate collector has been slow as John has been busy making the die.
See below Vid
He is making this die so he can beat the pipe into this shape for each of the two wastegates entering the dump to form a venturi. I know this is getting out of control however i guess, him making these things is all a challenge to him also.
  • Like 1
bobby, with motec it doest stop haha by the time i finished with my car it was well into the 30s!! wiring, slm, dash, 1 million sensors it gets up there fairly quickly!!
Yes i know i was just told today i have to use some special wire "tefzel" for all the sensors with raychem.
Also i dont see anyother ECU out there that can do what i need it to do.
Awesome build dude keep us posted !
I know of a good ECU "Apexi power fc" does the job for me lol
loving the thread mate. great stuff. I would love to come and talk with john about his ideas one day. he is a fantastic craftsman that's for sure.
I run a motec in my 32 too, not nearly as comprehensive as yours though! but it does run very nicely.
I'll echo some previous thoughts on using an EFR turbo. I have a lot to do with both borg warner and full race at the moment and would be happy to make an introduction? I'm sure they could supply the info john needs to make an informed decision about their product. pm me if interested.
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
