having met john and spent a few hours(!) talking to him I have utmost respect for the man. he has amazing skills and a brain that operates on another level to most. I have a pretty high IQ but john must be off the charts. Very nice guy too and not afraid to tell what he thinks and usually has very sound arguments to back his opinions too. he has some amazing ideas about a whole range of stuff.
I've no doubt this will be off the charts. I want to go back and ask him some more stuff. just need time for my brain to digest the last bits of knowledge he dropped on me!
thanks very much bobby. I really appreciate the intro mate. and your time too. :)
You lucky duck!
Hey Richard,
Glad that you liked the meet with John.
Yes it does get like that, does take time in digesting his knowledge.
Speak soon
Below pic, I have installed the Zeitronix Ethanol content sensor that gives you the concentration of ethanol in E85 Fuel. This is a must when running E85, last thing you wont to do is give it a hit and you lean out cause the ethanol content has changed, this is connected to a return line. Just Engine management is a Dealer for Zeitronix products.
http://www.zeitronix.com/
Theres a writeup in the Forced induction section if you dont check it often, by a guy who has used that sensor with a Link ecu, a local tuner has got the car running on anything between 98 and E85. Check it out, good read.
Yes very well put together thats if you want to run 98 and E85, what i am trying to do is only run E85 however as you know the concentration varies so we need to know the ethanol contant accurately . Tune can vary to fuel temp also when using E85 i have noticed he has not allowed for that.
What's the plan to alter the mixture of E85 if it is found to be varied from the original tune state? Add denatured Ethanol and/or BP98?
What do you do with ignition tables in regards to varying ethanol content/fuel mixtures? Add an extra dimension vs ethanol content? Sounds like an absolute mission to get running at an optimum level.
I'd think that the optimum/safe ignition advance would vary widely when you started mixing fuels together, as opposed to making ethanol content based corrections to the fueling table which would correlate directly to ethanol content..
Below is an update of the wastegaste Venturi.
Progress has been slow as John is having alot of problems panel beating the 304 stainless as it needs to be annealed every time he needs to beat it and the time frame is short before it cools.
Looking great!
was at outback steakhouse with him couple nights ago
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
