I think I sat on his lap one xmas to take a photo :P
Awesome coverage !! What is ur ultimate goal with this car???
Eg Pro entrant at WTAC :)
LOL
Ultimate Goal would be too prove all the theories applied by John and people to copy it and understand it.
Yes I will enter the WTAC once all the bugs are sorted, and drag race it ( Andrew Hawkins GTR challenge sounds nice)!!
Sure is a work of art i doubt john will ever make this for anyone ever again!!!!
for sure. when he's done you should talk to john about all the dies and mandrels he's made for the bits he's making. would be great for you to have them should someone ever want to undertake this kind of set-up again. he's put so much work into all the tooling it's a shame it will most likely only ever lead to one production run being made. I know some of the tool he's made is sacrificial though and gets destroyed/modified as he goes along.
can't wait to see more mate.
All die's and drawing work will be kept for those reasons if anyone wants to attempt making it. It would be a good idea to see if a 5 axis CNC machine could make the collector!!!
yeah 5 axis machine would make it much easier and like michael said a 3 axis machine would be fine too. but yeah John is hardcore to have made it on just a basic mill.
it's definitely possible to replicate, and the collector is obviously key, but you can discount all the other little tricks and logic behind it too. that's the problem, anyone can copy something but if they don't fully understand it it's all too easy to stuff up the other bits that make it work and end up with something only half as good as the original.
still I'd love to see some of the stuff made. I know a few machinists who could probably do something with it. we'll talk later! :)
This project is a pure work of engineering genius.
Sadly these types of projects are too few and far between....and indeed the John Skolas of this world are even rarer!
Haters gunna hate. Its very easy to bolt on tried tested parts, call it 'engineering' and get the result you expected (and that 1000 other people have got)
Its a completely different level of engineering starting from scratch, putting theory into practice and analysing the results.
I am in complete admiration for you and this project. I just wish I had the time, money, skill and equipment to do it.....for now i will just live through you.
This project reminds me a little of the Greek Evo that is/was being built:
http://forums.bimmerforums.com/forum/showthread.php?t=1575817
http://forums.bimmer...d.php?t=1575817
Thank you for your admiration.
Once the car is finished and running you are more them welcome to see the car.
This Greek Evo WOW crazy love all the CNC work , I guess this is the only way to make complex parts.
For a moment there I thought the ribbed piece of billet stainless was an expansion joint, but after watching the vid a few times I heard him say slip joint. Since its a slip fit it will take up any movement without cracking. Clever design!
I especially like how he has gotten the wastegate pipe to seal to the slip joint. The pipe is a tight fit at room temp, but as it heats up the pipe will expand more than the billet piece, and it will create a seal. Reminds me of how the SR71 was built. All the panel gaps didnt close up until above mach 2 when air friction caused the skin to expand and seal up.
Astonishing work Bobby and John!
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
