bobby, is john going to make a support for the turbo/manifold?
is he expecting any problems form the manifold warping?
Hi,
No need to support the manifold at all.
Well once the manifold is on the car and running i doubt if we have any problems his engineered it well enough to keep away from any problems.
The head is at Wilkins engineering to drill the holes. This will help remove air locks above the combustion chamber in the head. Once its done i will port some pics of the work.
I have done some wiring on the car, i have installed pressure and temp sensors before and after cooler using 4 core tefzel wire.
Hey Bobby, are you going to come to SAU Nationals and bring along that Z-Tune of yours? Im sure everyone would love to see it there.
Hey Ian, Sorry just have to much work on atm. You are more then welcome to see John on the way back as we are 5 min off the freeway.
So who is doing the head porting and assembly Bobby?
Cleaning of the ports have been already done, no porting required, and i have posted pics of ports. This was done by John Skola.
Motor assembly will be done by Trevor ( Johns Close friend) . I sent the head to Wilkin's engineering to drill the head to relief airlocks, and he also linished the throttle body shafts. Ill be picking it up tomorrow so ill post some new pics.
Graeme Wilkins and John Skola worked together many years ago on race cars. This is why John gave me the green light for Graeme to do some work for me as John does not know many people that are capable of doing the job correctly. Graeme is based in Seven hill on Stanton rd www.wilkinsengineering.com.au.
The head needed the holes drilled to relief air locks above the combustion chamber, the holes drilled are 3.5mm using a Mill and making sure you dont go drilling into the port or the headbolt holes.
While the head was there, Graeme has noted down many measurements of the work that John has carried out on the head. ie port shape port cleaning and final port size. So if you wanted your RB26 head ported in the same manner as mine (as i now john dont have the time to do it) you can always go and see Graeme to get the job done.
Also Graeme has milled the throttle body shafts, gave him one that John did and he copied them to all three. This will help increase the area in the throttle when opened fully for increased air flow.
Did you get the head on a flow bench?
+1 to Wilkins doing great work on heads
Yes the head has been flowed and sorry i dont have the figures as john has the file somewhere, once i find the file i will list it with the rest fo the calculations he has done. File is worth a mint !!!!!!!!!!!!!!!!:thumbsup:
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
