Beautiful. Plenty of clearance.
Are you using some kind of external regulator for those two feeds so you can control the oil flow to the head via pressure adjustment? Or just running larger orifice restrictors inline somewhere that can be changed easily enough? Say like a pill holder on the return side of a mechanical fuel system?
I am yet to find out i think it will be a restrictor in the system somewhere.
I will find out soon so i will update you
  • 1 month later...
Insane build by the way,
I was just wondering you might of already said, but what rpm are you going to be aiming for and what oil clearances on mains and big ends or is John going to stay with the factory specifications with the high boost and high rpm?
Also what pistons are you running and where did you get the wrist pins?
Thank you.
max rpm will be 9000 and the bearing clearance is just under 2 thou for the main and big ends.
The pistons im running a Custom JE pistons and they supplied the wrist pin. If you go to the begining of the thread there is a copy of the piston specification.
Dear bobby, please let me have your annual salary/bank balance <3 alby
On a more srs note, its looking bloody fantastic mate. Skola is definately an automotive legend, and deserves so much more. Has always been in the front of development and good ideas!
Hi Allan,
I think its nothing to do with salary its more to do with the amount of hours has been put into this project.
Thank you John Skola has put in alot of effort getting it all together
  • 1 month later...
don't see it there, sorry
http://www.youtube.c...c.1.4BSS8sX3apk
you mean there's a window for each runner that exits from the billet collector and into 2 'wastegate collectors', and then from the 2 wastegate collectors into each wastegate?
Edited by black bnr32
  • Like 1
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
