  • 3 weeks later...
After a Painful and Pleasurable couple of hours reading the build, I'd have to say this is a work of art with craftmanship and care i haven't seen before.
Hope the best for your next stage :)
and keep me posted
  • Like 1
Rightio. I had the pleasure of going for a little squirt yesterday in the absolutely epic car. It wasn't a long drive, it was enough to get the feel for the OS88 in it. Absolutely sold. Definitely not as "agricultural" as what I would have imagined.
The first thing that struck me was how quiet and tame it is while idling. No "grump grump, lots of overlap, big cam crap" going on, just a smooth as factory idle. The noise that was coming out of the exhaust wasn't that much louder than a factory car also. Pulls well from down low but you can tell its just screaming to be wound up. 15 psi, its not even trying.
The level of detail is second to none, anyone that has looked over this car would attest to that.
Thanks again for your time Bob, you didn't have to do that. You have just spent $16,000 or so of my money. :P
  • Like 1
Good too see you liked the car.
Well i built it so its an example for people to copy and experience 8)
Ill see you on the road with your new Box
How do you feel spending $17,000 of my own money. Jerk : P.
  • 1 month later...
  • 2 months later...
Hi Bobby, enjoying the thread, tech goes over my head but all good.
Have you had the final tune yet, love to see the results and hope you get what you were after. Looks great :wub:
I am going for response and would be pissed if my build takes 3 months, buy the parts and have someone stuff it under the bonnet and hope for the best :yes: But nothing like the effort you have put into this car :woot:
You can sell it now and start all over again,haha :action-smiley-069:
  • Like 1
  • 1 month later...
Finally made the time to read every page of this thread thanks to G20 long weekend.
Bobby I am probably not alone in saying it would be really appreciated if you could close this build thread out with an update on how everything turned out.
Thats way it is available outside of your Facebook page and easier for people to search/find.
Thanks in advance
Stretch
  • Like 1
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
