Hi Nick,
This motor build will have both with minimum lag or no lag so response under full boost and response in boost. The boost we are looking at running is 64psi absolute on the turbo side and that should equate out about 34psi gauge before the throttle bodies, remember this is all calculated, we will be follwoing the laws of Joule thomson effects.
You must all have a read of the below link now you know why people run big boost rememebr when the F1 where turbo they used to run 5bar boost.
http://en.wikipedia.org/wiki/Joule%E2%80%93Thomson_effect
thanks, should be a real animal with that much boost + revs :worship: ... that link is a bit over my head but I'm trying
those 80's F1 engines are ridiculous, but plenty of lag there;)
I guess we shouldn't complain too much, the old Sierra Cosworths were much bigger p1gs than our GTRs
I guess the modification to your quench pads will help you run such a high static compression ratio with quite a substantial amount of boost.
What fuel will you be using, I think I missed this further back ?
The squish area has not ben touched however the clearance has been changed by closing the gap further then standard.
The car will be tuned on E85 caltex.
Below is a pic showing how the wastegate will merge into the dump pipe and act like a venturi to help remove gases from the turbine.
Also there will be an addition of a fitting fitted at the bottom of the manifold collector, that can be connected to compressed air on board and spray it in for boost at idle, a good ay to launch of the mark. I know this is all new to alot of people as its all new to me, will have to see how it all works.
I will make sure i get detailed pic of the merge i hope people can copy this method and use it to there benefit
How did you form it? I'm also impressed with the manifold merge collector. I like to see people trying new things (well old theory, but not common ground). Keep up the great work.
Here are some old pics on how the collector was made, it took 100hrs to make
Design started from this
A wooden template was made first to see if it would work
Made from billet 321 stainless
I'm pretty eager to see how the dump will terminate, because at the moment it has the makings of the best possible solution for exhausting the gases.
The interesting part will be the packaging, unless your planning on running a side pipe :P
Very very nice fabrication work.
Thank you the fab work is not easy.
Will be running a full exhaust this car will comply to RTA road rules and comply with emmisions also
Hi Bobby, can you update with photos to show how this will work?
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
