im thinking of getting my 32 diff welded so its always locked and its my daily but is all the storys true that it can snap. knocking noise when taking full lock turn. ?
or to get a 2 way which is hard to find in 6 bolts ?
https://www.sau.com.au/forums/topic/355620-to-get-my-diff-welded-or-get-2way/
If it's your daily and you're worried about all that stuff, then just shim up your stocker.
Or..
Don't be a pussy. My 32 was daily driven with a button clutch and 2-way for a couple of years.. good times :ermm:
Try driving an N/A, RWD, 1 tonner V6 Rodeo.
That thing comes with a locked diff as standard, chirps out something mean and is an utter death trap in the wet! In the dry though that thing is awesome fun.
I'd say your mild manned N/A would be safe with a cheap weld!
i assume you mean to say it has a factory fittled LSD.
Locked diffs are illegal for street use, so i highly doubt your car has a factory locker. (reason being, they promote understeer when small throttle inputs only are applied.)
Imagine that nanna jenny gets in her hubby ute... she goes down to the shops but being elderly and irratic in her driving she comes straight off the throttle and turns hard and late at the first corner she gets to... now if there is no throttle then how is the inside wheel going to break traction to spin at constant speed with the outside wheel when turning.... it wont. it will want to push the car in a staright line.... see what im getting at.
this wont be the case in all chassis or road conditions. both my 33s have had locked differential and i have not had those problems but in other chassis it is a problem.
But it may well be a very tight lsd. Most decent four wheel drives and utes come standard with or are available with a farely heavy duty lsd.
  • Like 1
+1
definitely heavy duty lsd then haha
yup. and its sooo much better than having a 1 tonner with an open center...they see a hill or some grass and just cock a leg and go nooo where.
yer of corse. many cars would be useless without lsd but from factory the lsds start to lock up upon acceleration.... not deacceleration.
track cars... yer grab a 2way lsd or a locker. in a drift car its good for obvious reasons and in a circuit car you usually getting ready to get back on the power by the time ur at the apex. also there generally isnt trees or power poles at a race track lol and u have better rubber on the car so the front has half a chance at fighting understeer. (but better rubber at the back can also increase its tendancy to 'drive straight' if rear is locked.)
by 6 bolt does it have 6x1 or 3x2 pattern?
cheers everyone.
thats very unlucky for ur mate.
yes its 3x2 .
and so what if its non turbo big deal your car might beat me on a straight but "Men with guts attack those corners!"
yeah just checked mates his welded diff has been fine.
because a 1.5 way is not predictable to a 2way or, welded always predictable.
  • Nope 1
A 2 way (even a tight 1.5 way) will push the car into understeer. A locked diff is worse. Much worse.
That is nonsense A 1.5 way is as predictable as a 2 way. It also allows the car to handle a whole lot bettr because the diff doesn't have the same propensity to lock on the over run.
Bottom line: dont run a welded diff on a road car. Not only is it illegal, it is dangerous.
Edited by djr81
  • Nope 1
honestly, i have had a car with a welded diff, and i have driven a number of other with them, and i never had a problem with it on the streets )apart from the skipping noise when doing a tight turn around cops ;))
i do however agree that a propper 1.5 or 2 way is 100 times better, but i'd rather have a weldy than a single pegger!
as long as you are aware of it, then there should be a danger, just dont give the car to the mrs ;)
  • Like 2
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
    • The ones in brackets are the first stages of tightening. I usually aim for the middle of the range. They give a range because it's actually not that critical to hit exactly the right bolt tension. Enough is enough, and too much is too much, and the range given is inside that range. Half of the bolts in the suspension are problematic for putting a torque wrench on anyway, so just get done up to mechanic tight  and spanner checked a week later.
