Good morning gents,
I have a RB26dett in a 'S' chassis and I am having power fc memory problems,
I plug the power fc in and go to the menu to turn the boost controller function off and do so, exit the menu and then re enter it to make sure it is still there and yepp all is good, but as soon as I turn the ignition off and turn it back on it has reset itself to out of the box settings again??
I have z32 afm's and no pfc boost controller so my car won’t start unless I change these settings? any suggestions? This has happened to one of my friends sr20det and he got some advice to put constant power to a certian pin from memory he believes it was the coil packs or so but not so sure and everything was fixed,
With the standard computer and afms the car ran fine.
Any one have this problem before I know there is some very smart people on this forum that can help, thank you and appreciate it.
https://www.sau.com.au/forums/topic/355625-power-fc-loosing-memory/
That will be an issue with wiring to the ECCS relay. The ECU uses that relay to turn itself off after settings have been saved. The relay needs permanent 12v in not ignition 12v.
I have the same issue in my race car, it looses PFC changes if I turn it off using the kill switch because it cuts the permanent 12v power before the PFC saves
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
