after having several cars almost merge into me with my hand on the horn - i've decided that my car horn just doesn't have the impact that it should.
so I was thinking of grabbing one of those "stebel nautilus" ones from ebay. they say the dB is 139dB and up depending on the model you get. i've heard the horn and it sounds like it would get peoples attention
Does anyone know if there is a max dB level that can be used for a horn? or is it a case of, as long as it's not the musical type and constantly on, its all good.
Cheers
https://www.sau.com.au/forums/topic/355633-car-horns/
The horn on the GTR is very poor, almost apologetic... I've tossed up the idea of getting one of those aftermarket ones for a while now. The Clio has a great horn, as do a lot of Euro cars, have thought about checking out a wrecker for a second hand one, but those stebel ones seem pretty cheap...
https://www.sau.com.au/forums/topic/355633-car-horns/#findComment-5693961
This is what i found for NSW not sure whether it applies to the whole country. EDIT: Maybe you should call the EPA or someone like that and get it from the horses mouth.
Noise from motor vehicle horns
Horns cannot be installed or used if they are louder than the level in clause 21 of the Regulation. This level is 120 decibels for noise made up of a single non-varying loudness and pitch or 85 decibels in any other case.
Police and Emergency Service vehicles are exempt.
Horns should be used as traffic warning devices only and not as a means of relieving driver stress or frustration.
http://www.environme...ehiclenoise.htm
Edited by Shazza24
https://www.sau.com.au/forums/topic/355633-car-horns/#findComment-5694021
Haha yeah... This thread inspired me to research it a bit more.. It came on my car from japan..
I found it on google... It's actually a cool bit of kit..
Has two modes controlled by a switch... The box advertises the as:
"PA!!!!"
And...
"PAAAAaaaaan"
Haha basically u flick switch and it turns it into a tapered sound like a train
https://www.sau.com.au/forums/topic/355633-car-horns/#findComment-5696743
You need to get one of these. Maybe get one with a carbon fiber warp and mount it to the pillar? Perhaps put a neon light inside it?
If I get cut up by some hoon I find it therapeutic to imagine the rubber end is the guys scrotum? I can work out my rage by squeezing and twisting it, whilst simultaneously making an aural expression of my displeasure. :)
https://www.sau.com.au/forums/topic/355633-car-horns/#findComment-5696812
Someone cut in front of me this afternoon, and I actually went through the mental process of
*idiot*
*I'll horn him*
*actually, that's right, I'm in the GTR, this horn is p*ss poor so it's going to sound pathetic*
and I let it go.
The R34's contribution to a more utopian society.
https://www.sau.com.au/forums/topic/355633-car-horns/#findComment-5697910
Get a Vuvuzela...
I actually used one of these out the back window of the old mans Mitusbishi express. Travelling back from the Bathurst 1000 on the Bells line of road. Nearly got cut off by a silly woman, so blew the f**k out of one of these at her and she broke so hard she locked up the front wheels!! :cheers:
  • Like 1
https://www.sau.com.au/forums/topic/355633-car-horns/#findComment-5698008
i bought a set of air horns for my silvia because i was sick of getting cut off by tards in traffic.
anyways, at first the two horns weren't that loud but i had the brilliant idea of only using one horn. so double the air into that horn would make it louder and it made a huge difference. It's quite a lot louder then a normal "beep" horn.
I was thinking about buying another air compressor to increase the volume even more.
Edited by Peter89
  • Like 1
https://www.sau.com.au/forums/topic/355633-car-horns/#findComment-5698546
I'de edit your last sentence, while you still can hahaha.
https://www.sau.com.au/forums/topic/355633-car-horns/#findComment-5698562
Was the biggest disappointment after buying my GTR.
First time I hit the horn ( I use it a lot in Japan with the amount of idiots on the road) I wanted to crawl under a rock and hide.
My misso's Jimmny's horn was way,way louder.
Not anymore. Change of horn was my first mod.
I always love winding up the staff in Super Autobacs with their air horn display.
Bunch of horns all wired up with test buttons. Press them all at once and its a hell of noise and staff come running....sumimasen
https://www.sau.com.au/forums/topic/355633-car-horns/#findComment-5698719
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
