  • 1 month later...
I have a work colleague that does carbon work and may be able to fabricate some in carbon, I can oraganise a group buy but will need to generate more interest, any1 interested?
get to it man
Got a ballpark price figure, will b about ~$300 + postage, but pricing will lower depending how many buyers there are, so far its just
1. ooskylineoo
2. 75couope
3. ahh 33 s2
4. eiregaus
If had twice the numbers, it will b significantly cheaper :)
Thats just a rough figure from my work colleague guys so dnt try hassling me its not even my pricing lol, if I get more interest ill open up another thread in GB section :),
Spoiler will b PROPER CARBON ..won't be a dodgy fibreglass mash with 1 layer carbon. If goes ahead well be 1 of the very few if not first blokes with it in carbon =D.
Any more takers?
can you get some photos of some of his CF work completed?
How thick would the roof spoiler be in the end? would it be hollow or just a half shell production?
What will he be using to make the mould, need to be sure of final shape.
its still on my car man lols i said might be soon, provided it comes off the back window undamaged which i think it will for sure then yeh i rkn it'll be for sale, stripping parts off this weekend ill keep ya posted bro
$300 lol got mine (non carbon) for like $120..
better off tryin to make an s14 carbon one fit which are like $200..
mine might be for sale very soon :whistling:
$200 for a brand new s14 carbon roof spoiler? where'd u find that from? not 2 mention u hav 2 mod it to fit properly ....I did say it is a rough ball park figure, but as he mentioned prices will drop substantially with more buyers.
I will find out 4 u guys and hopefully get sum pics up in a couple days :)
billy has a carbon fibre one on his 33 again from yahoo.jp deffs didnt cost $300
s14 carbon fibre ones are 200 i think.
http://www.importmonster.com.au/yahoo?cat=0&term=vanquish+r33
$80 sif get carbon..
i paid $30 for mine from memory, freight killed the price
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
