i just got one this week from streeter (fiberglass though). Took about a month to come in from first contact with him and cost me $160 delivered to my door.
I may also be keen in a carbon one if the price is right if not i'll just do mine with carbon film
can you get some photos of some of his CF work completed?
How thick would the roof spoiler be in the end? would it be hollow or just a half shell production?
What will he be using to make the mould, need to be sure of final shape.
Will be using fibreglass+ultratec to construct the mould, 3 layers of carbon and hollow.
Don't have a completed one just yet but will be paying him to obtain materials and 2 whip 1 up next week and c how it turns out :)
Bear in mind guys interested that price isn't final.
Edited by OoskylineoO
Sorry for delay guys, work colleague is just a bit tied up with some other carbon jobs but the hard n long bit has already been done (mould for spoiler has already been fabricated), shouldn't be too much longer before I get the final product in my hands and pics up :)
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
Sorry guys, work colleague is being held up with a lot of other carbon jobs mine is obviously not the top priority job. But it he will eventually get it done lmao, will still post pics and fitment of it when its completed anyway and see if any1 is still interested.
  • 2 months later...
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
