2Way, Seats, Wheels, Vertex Kit
Purchased intake noise for the MX5 YEAP, a zero performance mod, but, after going for a spin with one installed (passenger seat ride), for me it is well worth the LOLS it gives with the intake noises over 3k rpm, just like the ITB's dort...........minus the top end performance of ITB's 🤣 Hang on, it is mad AutoExe JDM shit, so I'll probably get a sticker worth + 5kw
Nah, just slow it down.
By 180 wanabe · Posted
Also I'm a little turned off by the engine being only direct injected. If you put a catch can on early enough this should save all the build up on the valves and intake ports ? -
This is a simple swap when you reuse the RB20 loom and auxiliaries. I run a standalone, but if I remember right, using the RB25 ecu you only have 2 injectors to inverse. There are many DIY's on this subject online, including this forum. -
Surprisingly the D6000 is only $1999, I'm waiting for the BF/CM sales, and hoping to get one cheaper. D4000 is well priced, still outperforms the 13" SVS PB-3000 and is like 1/2 the price at $1699 RRP. I do watch a fair amount of movies, and listen to EDM, jazz, symphonies, etc. so the lower notes from a subwoofer are always appreciated. The front 8" stage, just doesn't provide you with lively feeling, even though they are pretty bassy for a pair of large bookshelves. Then again, these days it's just playing Wiggles, Blippi and Ms Rachel, another reason the 3m wide cabinet exists, to hide all the audio gear behind it. They used to sit on a nice pair of stands, but as you know, they make good baby traps too.
